Originally Posted by scdaf
Don't understand why it's impossible to carry your key in your suit with the smart. Small zip-lock bag, suit with zippered pocket, surf away!
I can tell that you never surfed.....
Personally I do not think that any zip bag will be airtight for 3-4 hours, because eventually with all the paddling and movement your metal part of the key will make a hole in the plastic. Plus I do not want to have that huge blob up my a** when I am in the lineup.
As stated above only solution is disassemble the spare key. Do not forget to put the key ring on the metal part. It is serving two purposes. One is you can attach the key to the board shorts, and second it is will be impossible to open the door with out it because you will use it as a leverage.
CUBE
