Temperature and alarm malfunction - Smart Car of America Forums : Smart Car Forum
Old 10-29-2008, 01:56 PM   #1 (permalink)
Starting two days ago the temperature started to dip below 40 def F in the evenings and my car alarm started to go off continuously. Dealer tells me that this is his forth reporting of this problem and he has no solution and SMARTUSA tell me they never heard of this problem. I now face a 1.5 hour drive to the dealer who claims he can not fix the problem, any other suggestions?
Frank
frankbova is offline   Reply With Quote
Old 10-29-2008, 03:28 PM   #2 (permalink)
Details:
Do you park in a garage or on the street? have you turned off the interior alarm?
Old 10-29-2008, 04:00 PM   #3 (permalink)
Mine was being weird the other day in the rain. Went off 5 times in row, for no appearant reason. I had to visit service for different reason and mentioned the odd alarm behavior. The Gm said some of the alarm sensors have been put in crooked, so they checked mine. Ended up the chip in mine was either upside down or backwards at least thats what they told me.
Pasde2 is offline   Reply With Quote
Old 10-29-2008, 06:55 PM   #4 (permalink)
When my alarm went screwy last May, the dealer told me that some had been set off by expansion/contraction due to temperature changes. He wasn't sure if that referred to the sensor itself or interior movement detected by the sensor. Don't know if that was my problem, but it was cured by replacing the motion sensor. forestacademy's is a good suggestion. If turning off the interior alarm (pushing the center button with the tow hook on it) before locking the car doesn't stop the problem, then it's not the sensor. So, it's worth trying to give you and the dealer more diagnostic info. Good luck, it's a real PITA.
Old 10-29-2008, 07:44 PM   #5 (permalink)
It was parked outside and the temp was bout 39 deg F at the time of the failure, no wind.
I did turn off the sensor early this morning when I parked at work and again this evening.
A bit of a pain to get it checked since my dealer is 90 miles away and a check means a half day off from work.
Thanks for the suggestions.
Old 10-29-2008, 11:28 PM   #6 (permalink)
angel's Avatar
Might try looking at this thread.
Alarming Situation
I had a problem with my alarm. Turned out to be some kind of interior sensor.
alarm malfunction, temperature
Engine malfunction indicator akuptown1 smart Operation and Maintenance 12 11-19-2010 10:10 PM
Gas Gauge Malfunction daleharrison smart Operation and Maintenance 57 05-20-2010 01:49 PM
Alarm system malfunction Eleanor smart Operation and Maintenance 3 08-18-2008 05:31 PM
Also, I have a multifunction malfunction? doogster smart General Discussion 5 06-04-2008 08:14 PM
Alarm system malfunction mvaldes smart General Discussion 4 05-09-2008 09:22 PM
