Are these wheel adapter spec.s correct? - Smart Car of America Forums : Smart Car Forum
Old 05-26-2008, 04:53 AM   #1 (permalink)
lowndex's Avatar
I wish to use 16" wheels and tires. I know I need to measure the wheel for the correct offset. If I go to a metal shop and request custom 3 to 5 lug wheel adapters, are the specifications below correct?
Stock 3 lug wheel spec.s:
- stock bolt pattern: 3x112 mm
- stock bolt length: ???
3 to 5 lug adapters:
- bolt pattern: 5x112 mm
- bolt length: ???
- thread pitch: M12
- front center bore: 57,1
- rear center bore: 66,5
- front disk thickness: 20 mm
- rear disk thickness: 25 mm
Do I need this data for the disk thickness as well?
Old 05-27-2008, 03:20 AM   #2 (permalink)
Supporting Tuner
Evilution's Avatar
It really depends on the offset of the wheels you are fitting and the bore of the new alloys.
Old 05-31-2008, 07:33 PM   #3 (permalink)
lowndex's Avatar
Here is where you can buy wheel adapters
correct tire sizes?! vonhep smart Wheels & Tires 13 01-29-2009 05:42 PM
Wellsmart Adapter Status/Check out these rims... iconpyro smart Wheels & Tires 25 06-10-2008 12:24 AM
Reservations over new reservation, and am I even reading the correct number? S_M_ART smart Reservations 7 04-29-2008 10:23 PM
Oops, this is the correct one fuelpincher smart Videos 2 04-24-2008 07:33 PM
Where to get double din radio adapter? jpkherd smart General Discussion 5 01-30-2008 09:24 PM
