Originally Posted by spdickey
Can't fix a "problem" that is inherent in the transmission. All transmissions with a clutch vs. a torque converter will lose momentum when the clutch is disengaged, whether the clutch is operated manually or automatically as is the smart's.
However, I have driven both Euro 450s (Italy and USA) and also Euro and USA spec 451s. The transmissions are much smoother now than before, but its still a clutch based system. Let's be glad this has been revealed and discussed to death. Either you like it or don't, but Mercedes decided it was the best solution for a low cost, fuel efficient drive train for the smart.
cant fix inherent problem in transmission?
they have already attempted it, done it so some lsight degree, but it still is not right.
the issue is not the inherent problem in manual transmissions. a std solid feel manual transmission is one strongly preferred and wished for by many.
the problem is with the smart semi automatic manual, and possibly the particular semi-automatic manual type that is used on the smart, that makes it feel so primative, unrefined, and transmitting that feel to cause the entire car to feel like 'a loose bucket of bolts', regardless of why mercedes decided it was the one to be used.
the smart semi-automatic is simply an unfamiliar one that most beg for something else,
such as the much wanted 'solid feel' std manual, or a much accustomed to smooth std auto,
that drivers have experience with, have become accustomed to the refinement of those two transmissions,
and tend to want the same or better 'good quality feel', when deciding to spend near $30k in pretax earnings dollars, on a new car.
this is why, i am hoping, this strange feel, might be the result of some new benefit to the owner,
such as the possibily (i dont know if this is true ?) of since the computer is controlling the shift points, which causes an undesirable roughness unaccustomed to,
may also give less grinding and wear, and greater clutch/tranny longevity,
something that while unpleasantly occurs and is unfamiliar to the driver, if (?) known to provide protection for the car, would tend to please the troubled driver overall, as its seen as good for the car.
any engine/transmission experts here, have insights on the validity, or not, of the latter possible longevity boosting benefit of the smart semi-automatic?
