TPMS Location - Smart Car of America Forums : Smart Car Forum
Old 01-14-2009, 10:59 AM   #1 (permalink)
Smartmadness.com
2micro4u's Avatar
TPMS Location
Can anyone tell me where are the TPMS (Tire Pressure Monitor system) on the smart wheels.
Is it inside the valve stem or mounted somewhere on the rim??
2micro4u is offline   Reply With Quote
Old 01-14-2009, 11:02 AM   #2 (permalink)
Mounted on the inner end of the valve stems.
Old 01-14-2009, 11:02 AM   #3 (permalink)
I would say that they are connected (or a part of) the valve stem. It is metal which is usually a good indication (sp?) of that.
Old 01-14-2009, 12:53 PM   #4 (permalink)
Pg 67 or 68 in the tech manual.
Old 01-14-2009, 12:58 PM   #5 (permalink)
For sale pm for details
Turbo42's Avatar
the valve stem has a nut you unscrew it and off the sensor comes. that nut holds it on. the actual sensor is on the inside of the rim
Old 01-18-2009, 08:02 PM   #6 (permalink)
ultrajim49's Avatar
Is the TPMS on the valve stem re-usable? By that I mean can I re-use it if I buy different aftermarket wheels? Is there anything special I need to look for it aftermarket wheels if it is re-usable?
Thanks in advance for any info.
ultrajim49 is offline   Reply With Quote
Old 01-19-2009, 08:12 AM   #7 (permalink)
Smartmadness.com
2micro4u's Avatar
Yes you can reuse the sensor. IF you get aftermarket rims I would reccomend had the rim or tire shop remove your OEM sensors from your OEM rims and have them put on your aftermarket rims to save you money from having to buy them all over again for they are expensive at the dealer.
I heard some rims the OEM sensor will not work but I have not found that to be true yet. Im very happy with my reused sensors./
2 - OEM 451 rear wheels with or without TPMS cablvr Archive/obsolete (?) threads 7 01-12-2009 06:22 AM
Disable TPMS? Possible? theSMART1 smart Wheels & Tires 1 10-15-2008 12:04 AM
TPMS issue Trena smart Wheels & Tires 14 10-01-2008 10:26 AM
TPMS needed... Nicholas smart Wheels & Tires 0 09-11-2008 06:08 PM
Removing TPMS sensor DAVE61353 smart Wheels & Tires 10 07-15-2008 12:07 PM
