Originally Posted by dbwill
A demo car will shift nothing like your own car will after you have driven it for a while and the transmission has "learned" your driving style. The consensus of folks in our area is not to lift your foot for the shift. After about 1000 to 1500 miles it will greatly improve. I have found that for normal driving (easy and mild acceleration) automatic works just fine. If you have to accelerate rapidly, I have found that using the paddles or shifter leaver gives better and more control.
This is an important copy of your own post....
<<<<The first test drive felt to me like a man was hunkered down in the gearbox, clutching and shifting as best he could (
possibly still learning). >>>
The demo cars are constantly being confused to learn a specific technique in shifting because different drivers have driven it and they had differing shifting habits. When you get your own, it WILL learn your driving style and you will find it to shift better and better.
When I first started using the automatic mode after I got the engine broken in (initial shift schedule too flat for break-in according to my experiences so car was exclusively driven in manual mode for 1st 1000 miles) I was lifting slightly at each shift point. I quickly found that technique to be pretty much a useless practice and stopped doing it.
Before long, the shifts were much smoother and quicker (but still with some delay) and as DB and A2 have said, the trans seems to loosen up some and shifting gets smoother and more at points where I shifted it in the manual mode. It really did adaptively learn my shifting habits. Basically, it shifts into second just before 20mph, third just before 30 mph, fourth just before 40 mph and into 5th at 50. The downshifts as you brake and decel will shift almost the same if you pay attention to what it is doing as it is doing it.
This transmission, IMHO, is far and away the sleakest transmission I have ever used. Having the ability to select a manual mode or auto mode to suit driving conditions is pretty trick in my book and adding to that it's ability to adapt to your driving habits is an added plus.
So moderate your opinion of the way the trans works based on what has been said here by owners rather than journalists (unless the journalist owns a smart) because chances are the car they drove was trained by a little old lady or a some Nascar driver and the transmission may be so confused it doesn't know when to shift for you....
John
