Originally Posted by stevenvillatoro
Russ, what is the install procedure? BTW, I'll be swapping my silver panels for whitie-tighties like yours... nice combo!
Steven,
I mounted mine on the left under the vent. I'm the right height where I can see it except when I turn and then I don't care if I'm getting ultra mileage or not. It will stay out of the sun, tucks in like it belongs and leaves a space to still put stuff.
I put 4 layers of 3M 3/4" double sided super adhesive tape on. It needed the four to get it tall enough to clear the head of the screw that hangs down. I don't trust the Velcro and my experience with 3M is great. There is an area just ahead of where the fabric of the dash stops so it makes a great surface to hold to.
I took someone elses tip and put a pull wire through the small opening at the top of the storage tray, to the right of the fuse box and the left of the steering column. Then taped the Scan Gauge to the pull wire and brought it back. Just watch the clearance to the steering shaft, tie wrap the excess wire to the fabric covered thing next to the column and it's all done but the programming.
I like the white, real pure. I think the all white Barabus is really sharp. I might start with my rocker panels, but I don't like the rear pan or the front spoiler so will be searching for good aftermarket ones for those.
