Originally Posted by Westfield 11
I thought most cars understeered nowdays, it is not that easy to find a car that will hang out the rear end and "back into" a corner. (sportscars excepted) It is particularly hard to find a FWD car that does not understeer and since most cars these days are front drivers..... Anyway the carmakers don't want to build a car that surprises the driver by doing something unexpected. (can you say class action lawsuit and contingency lawyer, children?) I know the smart is RWD, but after the A-series and the infamous moose incident MB overreacted and engineered all the performance out of the handling.
Understeer means you will leave the road nose first, oversteer means you will exit the tarmac trunk first unless you spin 360 degrees. ;)
You are right, of course, I knew what I was thinking, but it some how got switched on the way to the keyboard.
The understeer, oversteer terms have always had mixed meaning for me.
I was taught that oversteer meant you had too much turn cranked in as you hit the apex of a curve and could unwind and ease the G load. Where understeer meant that you hit the apex with NOT Enough turn cranked in and had to tighten up even further.
A rear engine car has a lot of weight out on the arm in back. It's sure to follow it around in a spin. ( Rolled up a bunch of
fence on the old Hollywood freeway in my Bug one day.)
No dispute here but would really enjoy discussing it further.
Regards A2Jack.
