Has anyone tried using port-a-walls on their smart? I purchased a set and think they would really look GREAT on my silver cabriolet with chrome wheels (see my gallery). Tire dealers are discouraging me from having them installed due to the possibility of an air leaks.
Any comment from the forum would be appreciated.
Bill
April 15, 2009 - NEW SHIPMENT HAS ARRIVED! ALL SIZES SHOWN ARE NOW IN STOCK.
A PORTAWALL SET CONSISTS OF 4 PIECES Portawalls, sometimes called slap-ons, Mickies, fake white walls, etc, available in a variety of wheel sizes and widths were originally designed to work on bias ply tires some 50 years ago, not today's radials. Bias tires have a flat rigid sidewall, and a much higher profile (aspect ratio) than radial tires. There is a lesser likelihood of them adhering properly to a radial because of the radius and flexibility of it's sidewall. The lower the profile of a radial, the less likely you will be pleased with the results. Larger radials with a 75 profile seem to work fairly well, but we do not recommend trying them on many of today's popular 60 profiles and smaller. For radials, we suggest the narrower widths, so they won't extend beyond the radius of the sidewall.
Installation is critical and the sidewalls have to be extremely clean to increase your success rate. We recommend a de-greasing agent, not a solvent be used to wipe between the tire and the rim to ensure that the area is very clean. DO NOT use a soapy compound, or the portawalls will slip out during re-inflation. Further success may be achieved by keeping radial tires at maximum allowable inflation and with the use of inner tubes to firm up the sidewalls so they don't flex so much.
PORTAWALLS ARE NOT RETURNABLE, unless you've selected the wrong wheel size and they are unopened, in original packaging.
