Windshield washer fluid problem - Page 2 - Smart Car Forums
 3Likes
post #11 of 13 (permalink) Old 01-11-2017, 11:13 AM
Miss Mercedes's Avatar
Quoted: 148 Post(s)
The lines in my 451 sometimes get cold enough to make it come out as a "slurry", but a second of clearing the lines fixes that. With the 453, the actual fluid itself appears to be freezing.
Maybe MB put a higher temp fluid in the 453s as opposed to the 451? It smells the same as the original 451 fluid, but apparently seems to have a different freezing point.
Miss Mercedes is offline
post #12 of 13 (permalink) Old 01-11-2017, 12:02 PM
Quoted: 30 Post(s)
Just a guess... but is it possible that the factory filled the reservoirs with the equivalent of RV antifreeze? While this stuff does turn slushy or freeze at low temperatures, it does not expand in the process as water does, and consequently break things.
RV antifreeze is also known as propylene glycol. It is a food additive and when heated produces the fake smoke used in fog machines and in some vaping liquids.
~toaster
Miss Mercedes likes this.
toaster is offline
post #13 of 13 (permalink) Old 01-11-2017, 12:43 PM
Quoted: 338 Post(s)
The Mercedes Winter Fit stuff is supposed to be mixed with water. I wonder if the dealers actually use it, and if so at the right concentration/proportion. It is expensive. Researching ingredients I look up MSDS sheets. I could only find it for Winter Fit in another country's Mercedes site, I think a country with .Au. It is a more complex solution than others I've looked up. If you have sprayers to the headlights I guess you could use it to help protect them from getting damaged, for example UV fading/opaque. (You know what I mean I hope. Wait, I think I'm still in the 451 side. Not a concern for a 451 as I know. No clue whether the 453 has sprayers to the headlights.)
Sent from my MT2L03 using Tapatalk
jzchen is offline
Human Verification
Windshield washer fluid not working in front twist86 smart Operation and Maintenance 14 02-20-2017 07:57 PM
The cold and my windshield washer fluid Jakieowner smart Operation and Maintenance 9 01-20-2014 06:27 PM
What this car needs is.... (a windshield washer fluid indicator) jetfuel smart Modifications 45 02-18-2010 10:58 PM
Factory Washer Fluid magilly00 smart Operation and Maintenance 26 12-16-2009 07:51 AM
Craziest thread ever! (washer fluid) fpage77 smart Operation and Maintenance 52 09-24-2009 09:12 AM
