Originally Posted by driven2succeed
Warning: The question below is probably indicative of my ignorance....
Can I ask why you are specifying STEEL wheels? Is this something I should worry about or just your personal preference? I have a cabriolet which I plan to drive throughout the winter. Is there some reason why I should not have snow tires mounted on the current rims and taken off again in the spring?
Not ignorance at all. When I buy winter tires, I normally try to find a new set of wheels to mount them on, so that I can simply swap the winter and summer setup whenever I want. I chose the steel wheels because they were less expensive than the original Passion alloys.
There's no reason why you couldn't have your winter tires mounted on the stock Passion wheels and then have the original tires reinstalled in the spring. The only issue would be the expense of having the tires mounted and balanced several times throughout the year, and the additional possibility of scratching the wheels because of all the tire mounting and removal.
