Old 02-01-2009, 08:45 PM   #1 (permalink)
Quagmire's Avatar
Is your steering wheel centered?
Just curious because mine is slightly off to the left. Anyone else have this and can it be centered?
Old 02-01-2009, 08:47 PM   #2 (permalink)
Ours is off center also - right in front of the driver's seat.
Old 02-01-2009, 08:52 PM   #3 (permalink)
Drive: 92 Crn Vic, 06 Civic Coupe
You need to have your toe-in adjusted so that the steering wheel is centered. This should be under warranty. It will not hurt anything as long as you are not experiencing irregular tire wear. The real issue is that the air-bag will not deploy correctly because the steering wheel is not centered.
Smart Bob is offline   Reply With Quote
Old 02-01-2009, 08:52 PM   #4 (permalink)
Godfather's Avatar
Oh that's cruel....... Quagmire, you need to get that fixed. Quite a few here are talking about abnormal tire wear.
Old 02-01-2009, 09:54 PM   #5 (permalink)
7,000 miles of smiles
mdfortwoguy's Avatar
Drive: '02 VUE, '08 Passion Coupe
The airbag is designed to deploy with the wheel in any position...
My wheel is off 1 to 2 degrees to the right. It annoys me, but not enough to take it in right now.
Old 02-01-2009, 10:32 PM   #6 (permalink)
Drive: 08 smart cabrio, Silver
Diabolic.
Kidding aside, I watch for that centering too - it started with my first Volksie; always something about toes. I want it purrfect...just like the headlight adjustment - that splendid line of light on the night road. I probably got it from my late, great huzband. 'Wheelman,' they called him, Lordy could he drive.
I just had the warmest flashback: I'm watching him work, music's wafting around the shop, and TJ, after replacing a big buick hood, takes a cigarette out of his shirt pocket, and runs it down the left and right sides - he tweaks a tad - until it's exactly a cig's width, all around. The consumate bodyman.
He blew some minds with some glasswork too.
God, he would have loved my smart. Sigh.
CruzinSusan is offline   Reply With Quote
Old 02-01-2009, 11:13 PM   #7 (permalink)
NeWave's Avatar
Drive: 05 Impala, 09 Passion
Mine seems off sometimes.. and other times it seems perfectly centered. Like I'll hold it center one time, and it'll go off to the right. Do it again later, it stays straight. Odd.. or I'm just looking for problems :P
Old 02-02-2009, 10:04 AM   #8 (permalink)
this is because your car may be tracking with the lean of the street, the front tires are very thin and dont have the side wall rigidity as say a low profile so you have more tire flex, like on super windy days my steering wheel is darn near turned a quarter turn to keep straight but thats when its like 40 to 50 mph gusts. wider front tires may solve the issue, i to thought it was off center but after watching the wheel changeg with the street i found it not to be the wheel at all and just the spongy front tires
4GAZM is offline   Reply With Quote
Old 02-02-2009, 02:13 PM   #9 (permalink)
JetFuel pass me a Carouna
2micro4u's Avatar
Drive: 08 SMART ForTwo Cabrio
Mine is off to the left...could it be that are cars need an alignment?
2micro4u is offline   Reply With Quote
Old 02-02-2009, 03:12 PM   #10 (permalink)
wrumbarger's Avatar
Drive: smart cabrio
Alignment needs to be done with proper weight in the seat?
This means that if you normally drive ALONE in your smart (and especially if you are larger than average), the shop should put your weight in the driver seat (or footwell). (If you normally drive with a passenger, then weights are not needed.)
In my case, I used to weigh in at over 400lbs, my cars steering wheel would always be off center and "drift" when I let go of the wheel. I mentioned the "off center" wheel status to my mechanic, and he told me about putting weight in the seat when aligning.
Steering wheel covers yuckmoon Smart Car General Discussion 10 09-01-2008 04:56 AM
Steering Wheel Adjustment The Silver Pellet Smart Car Operation and Maintenance 5 08-15-2008 02:44 AM
This is one beautiful steering wheel SMART Interior & Exterior 10 04-02-2008 07:12 PM
need a steering wheel cover smartyPantz Interior & Exterior 2 03-21-2008 02:49 PM
Adjustable steering wheel Westfield 11 Smart Car General Discussion 2 02-17-2008 11:01 PM
