Genius Newton 15" with 205/50s - Smart Car Forums
 5Likes
post #1 of 14 (permalink) Old 10-03-2016, 09:11 AM Thread Starter
ToddQ's Avatar
Quoted: 6 Post(s)
Going to purchase 4 rear rims and 4 205/50 tires so I can rotate.
I am having trouble with the forum on my phone, but believe I found posts saying they will fit.
My question is, do they stick out? Flush with fender? Recessed?
Thanks!
Sent from my SAMSUNG-SM-G935A using Tapatalk
ToddQ is offline
post #2 of 14 (permalink) Old 10-03-2016, 10:49 PM
Known as "Z06-LITE"
1983JZR3W's Avatar
Quoted: 116 Post(s)
On the stock 5.5" rear wheel, they should be just slightly recessed.
1983JZR3W is offline
post #3 of 14 (permalink) Old 11-03-2016, 08:04 AM
Quoted: 7 Post(s)
Four rears with 195/50. Perfect fitment IMO.
slolane, jzchen and davidp like this.
blackout is offline
The Following User Says Thank You to blackout For This Useful Post:
jzchen (12-02-2016)
post #4 of 14 (permalink) Old 11-30-2016, 11:48 AM
slolane's Avatar
Quoted: 2 Post(s)
I run 205/50 Kumho Ecsta PA31's on 15 x 6.5" Genius wheels that I run front and rear. These specific tires are directional so I can only rotate the wheels front to back. No issues after a couple thousand miles, no rubbing, no traction control issues, etc. On my old 2012 Pure I used to run the same exact wheels with 195/50's and they worked great too, to me the 205 or 195 ride so much better and handle the highway and wind a lot better than the stock steelies I had.
Here are some pics...
Hope this helps!
jwight and jzchen like this.
slolane is offline
The Following User Says Thank You to slolane For This Useful Post:
jzchen (12-02-2016)
post #5 of 14 (permalink) Old 12-30-2016, 07:15 AM
Quoted: 12 Post(s)
I know I have probably ask this question a million times. Do they rub when making sharp turns. I had the 195/50R15 on the front of my smart and they rubbed every time I made a sharp turn.
pinklady is offline
post #6 of 14 (permalink) Old 12-30-2016, 08:55 AM
Quoted: 255 Post(s)
Each of the wheels, in particular more with aftermarket ones, have different offsets, so it may be difficult to find a straight answer unless the owner happens to know the offset and width of the wheels on theirs.
Sent from my iPad using Tapatalk
jzchen is online now
post #7 of 14 (permalink) Old 12-30-2016, 07:00 PM
DrKillerBee
DrKillerBee's Avatar
Quoted: 310 Post(s)
I have the Genius 15" 6.5" wide wheels all around with Yoko S-Drives 195/50 tires all around with no rubbing ever...even on very hard race track turns or Dragon turns at speed. I also have the Brabus suspension which lowers the car ever so slightly. There are not too many aftermarket wheels for the smart so if you want to be safe find another smart owner that has the same suspension setup, wheels, and tires that you are contemplating and quiz them.
I can say that the car drives so much better on the highway and in turns that it should have come from the factory that way but then it was designed to be a city car that is economical and turns tightly for parking.
My new ED has the standard suspension and wheel/tire setup and rides more smoothly than the smart with the Brabus setup. It will only be driven to work and on errands so I plan on leaving the suspension, wheels, and tires as they come from the factory.
DrKillerBee is offline
The Following 2 Users Say Thank You to DrKillerBee For This Useful Post:
jzchen (12-31-2016), Smart Bob (12-31-2016)
post #8 of 14 (permalink) Old 01-10-2017, 03:18 PM
slolane's Avatar
Quoted: 2 Post(s)
Sorry for the delay in responding but as DrKillerBee noted, no rubbing for me when I ran 195's or the 205's that I run now. As note, I'm on the stock suspension.
slolane is offline
post #9 of 14 (permalink) Old 01-11-2017, 11:20 AM
Quoted: 42 Post(s)
all ED models are fitted with the brabus suspension from factory to cope with the added weight of the batteries ;)
davidp is offline
The Following User Says Thank You to davidp For This Useful Post:
DrKillerBee (01-11-2017)
post #10 of 14 (permalink) Old 01-11-2017, 12:24 PM
DrKillerBee
Quoted: 310 Post(s)
That is really cool to know. I haven't noticed much lean in the corners but wasn't aware of the Brabus suspension. The ED car runs more smoothly than my gas smart on Brabus suspension but my gas smart has 15" 6.5 genius wheels with 195/50 Yoko S Drive tires on all 4 corners. That wheel tire set up shouldn't result in that much of a different smoothness to the ride...but the rides are certainly different on the same road.
I have noticed the ED seats feel higher than in the gas smart car.
Human Verification
331
Bought GENIUS NEWTON 17" wheels - will they sit flush? yellowstone smart Wheels & Tires 23 05-04-2015 08:30 PM
smart car CUSTOM WHEELS - GENIUS 17" WHEELS - NEWTON - MATTE BLACK (4) SmartMadness Interior & Exterior Styling 1 06-19-2014 02:46 PM
Genius Newton 15" wheels Raygun smart Wheels & Tires 15 11-15-2013 09:51 AM
205/50-15 all round - 205/50-15 R/195/50-15 Performance Losses? Just George smart Wheels & Tires 27 10-23-2012 06:06 PM
