Originally Posted by Dan1776
To say that Smart "approves Mobil 1" isn't saying much. Sounds like more of a marketing agreement between Smart and Mobil than anything else. Any oil that has the required specifications and weight range as required by the car's builder is just fine to use. One only has to look in the owner's manual to see what the oil's requirements are and then make sure that the correct oil is purchased. I use Amsoil and have for 30 years because it tests much better than most anything else out there. Just my thoughts after many years studying oil theory. Dan
I concur. I see no reason to use anything else other than Amsoil. I plan on doing 15,000 mile oil drains with the 5W30 as long as I can use an EAO12 oil filter. Normally I would go up to 25,000 miles, but now that I sit in major stop and go traffic, I guess that would qualify as "severe" driving with all of the sitting in idle traffic. I used to drive 95% highway miles and would put over 30,000 miles per year. Back then I would use the 0W30 oil since it would last up to 35,000 miles.
There's no savings to using other oils being that you have to change them so frequently and Amsoil has a lower wear scar in the 4-ball wear tests as well as many other comparisons. I used Mobil 1 for many years until somebody told me about Amsoil. I had no idea that Amsoil was the first synthetic oil for cars to come out in the US. I am so mad that nobody told me about this oil sooner.
It's too bad that all of these major oil companies give kickbacks to the manufacturers to put their name on them, like the way Castrol does with BMW.
Amsoil beats the pants off of Mobil 1.
As long as the specifications for the Mitsubishi engine in the US for the Smart fortwo require "SM", then the
Amsoil 5W30 should work or even the better stuff like the
Signature Series (which costs a bit more money but shares some of the same chemistry as the Amsoil 15W50 racing oil.)
