Horn replacement - Smart Car of America Forums : Smart Car Forum
Go Back   Smart Car of America Forums : Smart Car Forum > Chapters/Regions > West Coast Clubs > Smart Owners Club of San Francisco
Old 05-20-2008, 12:27 AM   #1 (permalink)
starlord's Avatar
Horn replacement
yeh, last weekend i replaced the stock horn with dual air horns, ah what a nice sound.. there are two ways to do this. one is way easier than the other. you can remove the front and bottom panels with torx 20,30 drivers though that will take about a good hour, or if your hands are small enough (mine arent..) you can reach into the drivers side, see the blue and brown wires? those attach to the stock horn which is mounted there on brackets. you just need to figure out how to wire and place the air compressor, run the tubing to the horns and hook it all up in a way that will fit and not get in the way of other bits... i will take some pics later if anyone is interested?
starlord is offline   Reply With Quote
Old 05-20-2008, 01:26 AM   #2 (permalink)
factor9's Avatar
Sure, Starlord. I'd be interested in seeing pics documenting both ways of installing the new dual air horns, especially how you removed the factory horn and mounted the new one along with the wiring connections. Thanks! Gotta be a blast!
factor9 is offline   Reply With Quote
Old 05-20-2008, 06:47 AM   #3 (permalink)
farkas's Avatar
Here is everything that you need to know about your horn replacement. Pictures included. The write up is very good and easy to do.
http://www.smartcarofamerica.com/for...tory-horn.html
farkas is offline   Reply With Quote
Old 05-20-2008, 06:57 AM   #4 (permalink)
Yes, I'm interested. I would like to eventually install the Euro-characteristic, Hi-Lo, Alternating horn (two-trumpet air horn @ 540Hz - 660Hz). This one is a little lower in frequency and a bit slower: European horn sound effect .
It is distinctive without being anti-social and raucaus.
Old 05-20-2008, 10:34 AM   #5 (permalink)
factor9's Avatar
Thank you!
Old 06-29-2008, 10:32 PM   #6 (permalink)
starlord's Avatar
that link didnt seem to work, but I just posted pics and the 'easy version' install for the air horns.. here it is:
Twin Fiamm Air Horns Install
Old 06-30-2008, 02:53 AM   #7 (permalink)
A lot of the old links are broken; try this.
Two methods for getting at the horn: one is to remove the left front panel, the other is to go in through the left front wheel well.
Old 09-22-2011, 04:52 PM   #8 (permalink)
Horn Replacement
How do you remove the front and bottom panels of the car to gain access to the horn?
Steve144 is offline   Reply With Quote
Old 09-22-2011, 05:27 PM   #9 (permalink)
Admin/Mod.
Thanks to Kane:
BTW: this is a direct link to the specific page(s), not a generic site's link.
Old 09-22-2011, 05:59 PM   #10 (permalink)
starlord's Avatar
yep evilution is a great source for smart mods.
i just reached in and unplugged the wires from the stock horn,
as far as i know the thing could still be there, heh! (i've since sold the car)
cheers,
StarLord
Horn kip123 New Members Area 29 08-27-2011 03:37 PM
Horn upgrade cnwpledger smart Modifications 26 03-29-2011 10:23 AM
Stebel Horn W/B Smartie Interior & Exterior 40 11-18-2010 04:46 PM
Horn Upgrade Timini Hawaii Chapter 3 09-24-2009 03:49 PM
Fanfare Horn Old smart Interior & Exterior 17 06-14-2008 08:21 AM
