Old 10-18-2009, 12:14 PM   #1 (permalink)
powerbookguy's Avatar
15 x 195 Fronts and 15 x 225 Rears?
Hi everyone,
Forum newbie here, recently decided to get a smart ad have been reading the tire and wheel posts with interest.
I see many are running 15 x 175 Fronts and 15 x 195 Rears but has anyone gone with wider rubber in a 15" staggered setup, say 15 x 195 Fronts and 15 x 225 Rears or similar?
TIA.
powerbookguy is offline   Reply With Quote
Old 10-18-2009, 01:23 PM   #2 (permalink)
**Go Colts...9-0**
Big Panda's Avatar
Drive: Un Poco Panda
More info needed. What aspect ratio? 50, 55 or 60? I'm running 175/55R15's all the way around on OEM Passion 15x5.5 alloys.
Also, are you planning on running OE wheels or aftermarket? If aftermarket, then what size?
Personally, I would like to run 195/55R15's all the way around 'if' I knew for sure they would clear with no rubbing.
Old 10-18-2009, 01:54 PM   #3 (permalink)
To the XCAPEPOD!
rfernatt's Avatar
Drive: smart fortwo
15" 195/50s front and rear on 6" Rial rims with no problems.
Old 10-18-2009, 05:51 PM   #4 (permalink)
GHammerly's Avatar
Drive: 04 TSX, 08 smart
Check the tech. specks from the tire manufacturer or from the Tirerack website to make sure the diameter or circumference of the front and rear is close enough to prevent the stability control problems. I would just get the 15x6.5 Genius wheels all around with 195-50-15 Bridgestone RE-11. They should barely fit on 6.5 wheels, they are really the widest 195 tires I have ever seen and have monster grip.
Old 10-18-2009, 10:02 PM   #5 (permalink)
Why do that when you can put 195/50-15's all around with no problems? They're also virtually identical in rolling diameter to the originals so speedo and odometer are not affected.
Old 10-19-2009, 08:20 AM   #6 (permalink)
thanks for the reply. i was thinking 50s or 55s on either Rial or Genius wheels. i have just started doing my research.
Old 10-19-2009, 08:21 AM   #7 (permalink)
thanks, has the car been lowered at all? any snap oversteer issues?
Old 10-19-2009, 08:24 AM   #8 (permalink)
thanks, those do look like awesome tires. according to the specs posted by tirerack they should fit on the 6" rials as well.
is is just the diameter or circumference that can present stability control issues? tirerack shows the RE-11s are almost identical in size to the stock rears.
has anyone tried turning off stability control by pulling a fuse (assuming there is one)?
Old 10-19-2009, 08:26 AM   #9 (permalink)
are you running this setup? if so, which tires and wheels?
thanks for the help everyone.
Old 10-19-2009, 08:51 AM   #10 (permalink)
To the XCAPEPOD!
rfernatt's Avatar
Drive: smart fortwo
fortow and I are running identical setups (unless he changed recently): 15x6 Rial wheels and Yokohama AVID T4 all-season tires in 195/50 all the way around. I've been running this setup since last January for almost 20,000 miles. The car has not been lowered and is stock in all other aspects.
No rubbing and no oversteer issues that I've been able to detect even in 'sporty' driving that has activated the ESP a couple times. I had it on the Dragon run recently and even pushing it in the wet, there were no issues. IMHO, it handles better, rides better, looks better, and you can rotate. I've rotated this setup three times now. YMMV, but I can recommend this configuration without hesitation based on my driving.
OEM 9 Spoke Rears / fronts SmartDigger Smart Car Parts Marketplace 13 11-09-2009 04:58 PM
Wanted: OEM 9 Spoke Rears ulflyer Smart Car Parts Marketplace 1 10-09-2009 08:22 PM
Confirmed -- Brabus rears fit on the front silverbrabus Smart Car Wheels & Tires 33 06-09-2009 10:37 PM
what would happen if... (rears on front) holliwud Smart Car Wheels & Tires 68 06-01-2009 08:41 PM
For Sale: Four OEM Tires (Fronts and Rears) Hlf Pnt Smart Car Parts Marketplace 0 11-05-2008 12:53 PM
