Originally Posted by daleharrison
I would like to use my stock Passion wheels with tires of one size that I can rotate front to back. Can this be done without sacrificing safety and if yes what size tire will I need to be sure about not oversteering and clearance in the wheel well.
Although people have used the OEM front wheels with wider tires, that is not advisable, not even for the 175 sized OEM rear tires. The front and rear OEM wheels are actually different widths because the tires are different widths. The wheel and tire widths have been optimized. Unless wheel width and tire width are matched there will be a deformation of the tread leading to wear and traction problems. There is a range of acceptability however.
In this reference you can find a number of calculators - there is "
An ideal rim-width calculator" about 1/3 of the way down -
Car Bibles : The Wheel and Tire Bible Page 2 of 2
After-market wheels do not have to be costly. Also, if you use aftermarket wheels you will then have the originals for spares - or you can use them for winter tires.
You can use up to a tire width of 195 without any problems whatsoever, slightly wider may work as well but, as has been mentioned, a 195/50-15 tire will give you almost the identical diameter as the OEM tires.
"Oversteering" is not an issue since the car has devices to prevent that from happening. Understeering is more of an issue with the original narrow fronts.
