bmx43 yes good point... pre 07 450 fortwos had a distinctly different rim offset then our 08 451s will have.... don't keep all this crap in my head so not gonna post general numbers...
We have quite a few less options right now then the 450s have but we still do have options...
Like brother Don R pointed out...there is a practical max rim diameter of 17"... to stay in the proper diameter some of us will have 35 aspect ratios... this is a damned small side wall height and the ride will not be good for some folks tastes... plus any pot holes need to be avoided
My roads in this area are actually fairly good so I think 17s will be OK but if you have a lot of crap roads I recommend 16" and 40/45 profiles
The Speedo sense is from a gear train in the transmission. I expect the output is not a spinning cable to the back of the speedo but a electronic pulse to the ECU and ABS computers... sounds like to adapt to larger or smaller diameter tires a gear change is needed to re-calibrate to a true speedometer indication
ESP is a different animal... each axle has a tone ring and a mag pickup that sends a speed (RPM) signal to the comparison computers. This system is tied into the anti lock brake system. There are also longitudinal and lateral accelerometer sensors in the system... All of these inputs are used to counteract lost traction, under-steer, emergency stopping and several other subtle and not so subtle safety issues...
What I am saying is that while true, tire diameter can be re-calibrated technically to give a true speedometer reading, there is no effective way to compensate for the ESP safety features.... So it is critically important that any tire width changes maintain the factory designed diameters
They are:
The 155x60x15 works out to a diameter of 22.32"---931.8 revs per mile
The 175x55x15 is 22.57"---921.5 revs per mile
So if you do want wider tires on larger diameter rims you must make tire selections that stay very close to the factory diameter/revs per mile setting..... Because there is a slight split in the factory tire diameters it is safe to assume some small error can be compensated for...BUT not much
Think of what happens to a tire as it wears... it decreases diameter and increases revs per mile...thus there is a small range of error that the ESP computers can compensate for
I inquired as to speedo accuracy with the maven in Buckhead. He replied no change in accuracy as "17 inch wheels would not change diameter." (???)
The 17” wheels on the Brabus mount 225/35R-17s. They are a similar (enough) diameter to the standard 175/55R-15s because the aspect ratio is smaller (35 vs. 55).
