Alignments???? - Smart Car of America Forums : Smart Car Forum
Old 04-03-2008, 11:27 AM   #1 (permalink)
rasrx7's Avatar
Alignments????
Not sure if this is the right place for this, but has anyone thought about alignments? i just lowered my car on eibach springs and was thinking about getting it realigned in case its off from pulling out the suspension. Can a smart car be aligned on the regular racks? Is it too short? is this something only a dealer may be able to do?
rasrx7 is offline   Reply With Quote
Old 04-03-2008, 11:30 AM   #2 (permalink)
BandSofC's Avatar
Will a dealer bring your car in a service bay with a modified suspension?
I've known some dealers that won't change a wiper blade on a modified car.
BandSofC is offline   Reply With Quote
Old 04-03-2008, 12:51 PM   #3 (permalink)
rasrx7's Avatar
according to the crew at penske in west covina,ca , they are a mod friendly dealer. They sell alot of aftermarket parts for the others brands in there line. Im hoping they would service it, fingers crossed, since there are only so many of us out here modded.....i cant be 100% till i try....
Old 04-03-2008, 12:54 PM   #4 (permalink)
I guess the question is what are the "correct" settings for your car with lowered aftermarket springs?
Old 04-03-2008, 01:19 PM   #5 (permalink)
rasrx7's Avatar
so youre saying it something that ill have to do at home?
Old 04-03-2008, 01:27 PM   #6 (permalink)
No, just guessing the standard factory alignment settings won't be the best for your lowered suspension. It will take more than your neighborhood alignment shop to sort that out IMHO.
Old 04-03-2008, 06:18 PM   #7 (permalink)
rasrx7's Avatar
o hehehe... camber im sure wont be applicable..the rest should be adjustable.....but im more worried about finding someone with a rack it will work on....my friends says it might be too narrow for his rack and it might fall through..another friend says its too short to get it to fit on his rack....
Old 04-03-2008, 09:05 PM   #8 (permalink)
RussBarnes's Avatar
I wanted to put more caster in to make it more stable in the wind and since I have P.S. more caster would help this. The since this isn't a double wishbone the top is non adjustable and it didn't look too easy to shim or adjust the bottom, but that was a quick glance.
Old 05-06-2008, 09:37 AM   #9 (permalink)
First, the rear end is not adjustable in any way , not even toe .
The front has a very small amount of adjustment because the four bolt holes in the front lower assembly are larger than the bolt diameter and therefore can be slid
around for small amounts of caster and camber. Toe is adjustable at the tie rods.So, you might be able to adjust the camber difference by sliding the assembly left or right as far as possible. <****->
It might be possible to enlarge the holes for greater adjustment , but I doubt that any dealer would do it. Maybe an independent suspension company.
The 451 fits my rack with very little to spare. It is the latest Hunter scissor lift with the 'paddle mirror' system (DSP600)
Betoweb is offline   Reply With Quote
Old 05-06-2008, 09:59 AM   #10 (permalink)
Fredvon4's Avatar
Some myths...
Some truths...
the rear deDion from the factory is set (fixed) in toe and camber
camber on the rear can not be changed it is engineered into the hub brace
however rear toe can be changed is you remove the rear trailing links and install adjustable links
Front toe is adjustable DUH
There are sources for eliptical lower strut/hub bolts that allow -3 to +3 degrees of camber adjustment
front castor can not be changed
most Euro Tuners that lower the suspension are setting all angles and toe to factory spec... some add a few seconds of toe in
most lowering by spring change is only in the 25mm (.9 inches) or 35mm (1.3 inches)range...
this minescule ride height change doe not significantly change any dimension for castor, camber, or toe ...well not enough to make any difference
There are full coil over kits with full adjustability for ride height, pre load, plus shock absorber rebound and compression ratios, .... the kits I see can lower up to 45mm (1.75 inches)...
