Music Game
Old 06-01-2008, 12:26 PM   #1 (permalink)
Drive: 07 Prius, 09 Silver Pure
Anyone try 185/55's on rear
The stock tire is still only available from Tire Rack but I did notice a lot more Brands of tire if you move to a 185/55 R15. Has anyone tried this? I believe this means the tire is a bit taller. The good thing is if you need a tire quickly most of the larger tire stores carry this size.
Also any idea what the torque should be on the lugs?
Thanks
redbluff is offline   Reply With Quote
Old 06-01-2008, 07:26 PM   #2 (permalink)
jmcummings's Avatar
Not that I am aware of but DavidV is running 195/50/15's all around, just do a search on DavidV and you will find the thread.
Thanks!!
jmcummings is offline   Reply With Quote
Old 06-04-2008, 07:39 AM   #3 (permalink)
RussBarnes's Avatar
Drive: Excursion, smart, Kenworth
Just last weekend I put four Michelin 185/60 - 15's on and only have about 100 miles on them. Nothing hits if that is your question. Measuring the circumference shows that these are 4% larger around so I need to take calculated mpg and multiply by 1.04 to get actual milage. Any other questions? Plan to post photos when I get back home this weekend.
Old 06-15-2008, 03:29 PM   #4 (permalink)
RussBarnes's Avatar
Check this post on Modifications Interior and Exterior and you can see what 185/60's look like: Four 185/60-15 Michelins, powder painted rims, Doug Thorley Exhaust with body paint Sorry not sure how to direct link.
Old 06-15-2008, 05:05 PM   #5 (permalink)
Not Selling on Ebay
Drive: 2006 Mini CVT
According to my scangauge and gps my speedo is running 4% faster than the car is actually going with the standard rear tires. (50 on speedo, 48 scangauge and gps). If it is the case I'm losing 4% of my warranty.
Old 06-15-2008, 05:11 PM   #6 (permalink)
RussBarnes's Avatar
Mine was off too, but remember that these speedometers are calibrated by a theoritical tire diameter and I found that these Conti's don't measure up to what the theoritical spec sheet says. Mine were 71.125" circumfrence and that is 22.63" tall, fronts are actually taller and that is totally against tire spec sheets.
Go to an interstate, run for 10 miles at 60 (not on a busy day) and see if it takes you 10 minutes. It's hard to hold a steady 60, but if you do you can see how far the speedo is off and then adjust Scan Gauge to match true speed.
And in the fine print, I'm sure they can wiggle out of the warranty...lol
Rear fog lamp august8pm Interior & Exterior 47 02-02-2009 08:29 AM
Smart Car Rear-Ended cbjames Smart Car General Discussion 60 06-17-2008 05:37 PM
Rear Soundboard for 451 smartie1 Audio & Video 4 05-13-2008 05:27 PM
Sub and/or speakers in the rear hatch? Frankenstein_Casanova Audio & Video 17 04-21-2008 07:54 PM
Rear License shack01 Smart Car Operation and Maintenance 21 03-29-2008 09:17 AM
