Confirmed -- Brabus rears fit on the front - Page 4 - Smart Car of America Forums : Smart Car Forum
Trailer
Old 06-09-2009, 07:47 PM   #31 (permalink)
Brabus's Avatar
I just learned that run-flats don't exist for the 15" wheels between 145/40-15 to 215/70-15, but they do for 17s.
At least on tire-rack. 15 run-flats may still exist?
So I'm considering run-flats for the 17s as well as getting run-flat snow tires.
Run Flat sizes for the front
205/45-17 is a very common run-flat size and even has SNOW tire run-flats in this size! So if I put that on the front then I'd definitely would need a wheel spacers and/or spring spacer.
And there are a ton of options for a run-flat for the rear in any width 225 and higher. IMO, the Brabus needs a wider rear tire than 215 because it's a 7.5" width rim.
So now back to the drawing board.
The difference between 215/35-17 and 205/45-17 is I wouldn't need a wheel spacer fear of hitting the spring perch as the tire width is 0.4" (10mm) narrower.
However, the sidewall is 0.6" taller (17mm). That means the tire will be 0.3" (8.5mm) closer to the spring, so the spring itself is going to be a problem. I could use a a combination of both wheel spacer and spring perch spacer to minimize a frontal lift and widening the wheel stance. Or I could pick just one and go more extreme on widening or lifting the vehicle.
hmmm, guess I need to see what a 205/45-17 on the wheel looks like installed on the Brabus's front.
Old 06-09-2009, 08:57 PM   #32 (permalink)
Brabus's Avatar
Okay, so after looking at the Brabus. A 205/45-17 tire would require a spacer between the spring and perch.
A wheel spacer would have to be 30mm in order for that size tire to clear the spring,which obviously goes without saying would look ridiculous. Using a wheel spacer would be pointless even in combination with a spring perch spacer.
So now the hunt for a suspension spacer. I'm guessimating 10mm is what I need.
I don't have a problem with raising the front to standard Smart height, better crash protection and road hazard protection (i.e. snow on the roads). However, I do love tbone28 dropped Smart but that is only practical in warmer climates.
Old 06-09-2009, 09:10 PM   #33 (permalink)
tbone28's Avatar
Brabus - when calculating various tire sizes, keep in mind that sizes are not standard across different manufacturers. Some are wider than others, and some have rounded sidewalls vs. square sidewalls.
Old 06-09-2009, 11:37 PM   #34 (permalink)
Brabus's Avatar
Yeah, I just read what you wrote in your wheel mod thread after writing this in this thread. After reading that, it appears I might need a combination of wheel and suspension spacers afterall.
Does anybody know who sells suspension spring spacers?
Old 01-28-2010, 03:53 PM   #35 (permalink)
so... whatever happened with this?
Alchemy R is offline   Reply With Quote
Old 01-29-2010, 12:23 AM   #36 (permalink)
silverbrabus's Avatar
Decided not to do it.
Drove around for a day with the 17s on the front and they hit. Not just the liner either. Concluded that 7.5 is to wide for the front.
rubbing in front with 17s?
Old 02-10-2010, 02:32 PM   #37 (permalink)
Shoot, that's too bad. I was hoping that it was doable...
Old 02-10-2010, 02:33 PM   #38 (permalink)
Just read your thread there... are you lowered or on stock Brabus suspension?
Old 02-13-2010, 10:59 AM   #39 (permalink)
Lowered on H&Rs.
Drop your Brabus
Old 02-13-2010, 11:07 AM   #40 (permalink)
Hmmm, I wonder if stock Brabus Suspension would work with the 17's up front...
brabus, wheels
what would happen if... (rears on front) holliwud smart Wheels & Tires 81 11-09-2010 06:06 PM
2009 Brabus Smart - Options Confirmed! tbone28 smart News & Rumors 20 03-27-2010 05:24 PM
BRAND New BRABUS 17" rear / 15" front wheels bacque Archive/obsolete (?) threads 13 10-22-2009 12:00 AM
Four OEM Tires (Fronts and Rears) Hlf Pnt Archive/obsolete (?) threads 0 11-05-2008 12:53 PM
Replacing front wheels/tires with rears shine smart Wheels & Tires 16 11-02-2008 05:49 AM
