Front end toe in with bigger tires - Smart Car of America Forums : Smart Car Forum
Old 05-04-2009, 10:04 AM   #1 (permalink)
JimDantin's Avatar
Has anyone tried to tweak the front end alignment after installing bigger wheels and tires? I'm wondering if the stock alignment spec is appropriate?
Also, what tire pressures are you running?
I found the tire specs for the Pulse model -- 175/55R15 on 5Jx15 (front), 195/50R15 on 6.5Jx15 (rear) 26/32 psi.
I found the Passion alignment specs here, but I can't find the Pulse toe-end specs - I'm curious if they are different.
Old 05-04-2009, 10:13 AM   #2 (permalink)
To the XCAPEPOD!
rfernatt's Avatar
195/50s on 15x6s all the way around -didn't change anything but the tire pressures (28 front, 34 rear) and it has been working fine.
Old 05-05-2009, 12:55 AM   #3 (permalink)
iconpyro's Avatar
I am running 16X7s and I have not tried to adjust the toe in on the front. My wheels are aligned (when I brought it into do a tire rotation) There is still that same look on the back (it supposed to be like that) A lowering job in the back was performed about 6 months ago...
iconpyro is offline   Reply With Quote
New psi front tires rubyg smart Wheels & Tires 9 04-14-2009 04:18 AM
4 Front Wheels and Tires magilly00 Archive/obsolete (?) threads 8 03-25-2009 09:33 PM
OEM front wheels/tires only $100 ea kroko Archive/obsolete (?) threads 9 03-21-2009 05:17 PM
where to buy front tires virenr New Members Area 1 12-24-2008 07:26 PM
Front Wheels and Tires smartah Archive/obsolete (?) threads 5 09-07-2008 08:28 PM
