Old smart makes a good point...
To go much wider requires the tire aspect ratio get smaller and smaller...
to maintain the 22.5" diameter average... 205mm or wider will require 35 aspect... and on a 17" rim 35s have only 1.75" side walls... the TPMS system will be in danger of being crushed... probably also breaking the insides of the air fill stem they are mounted to...so broken $100 sensor and a flat tire is probable...
In my case, I intend to keep the factory alloys and tires as part of an 8 tire rotation scheme... the aftermarket rims and tires will not have the TPMS and I will live with the nag light pestering me....
