Originally Posted by WJReiss4
Did you make a change to the alignment in any way to accomodate the 17" C-class rims?
The rear camber seems excessive with such a wide rear tire... the outside edge might not be on the ground at the factory setting
Thanks,
Bill
The tread is about even in the front, and maybe 1/2" or so out in the back. There are a TON of pictures of my car on my website ( zenspeed.com ) which might give you a better idea of how they look. But remember, Josh and I are both using what I'd consider to be a fairly extreme setup for the Smart; huge Benz wheels with relatively low offsets. (34 and 36mm if I recall correctly) A set of 16 or 17", 6.5 or 7" wide wheels with 40+mm of offset (and not staggered with huge rears like ours) would tuck perfectly.
No alignment changes required. The rear camber setting appears to be fixed (non adjustable) from the time I've spent under the car, but I might be wrong about that. Anyway, it's moot, everything stays stock. Plenty of clearance at stock ride height too.
Johnny
