Originally Posted by sato7
Stick to 15" rims unless you want to increase the harshness of your ride...
195/55/15s is tops up front, while the rear can go a bit wider but 195 is great if you want to do the NON-staggered approach.. on a 15"x6.5" wide rim
stock will hold the rear 175s at best, by the way you can do a set of rears upfront with 175s no prob.
Hey guys - does this mean I COULD get wider tires on my stock, Passion, 9-spoke, 15" rims??? I've been searching for a bit and this is the first reference I've seen to using wider rubber on 15" rims. Out of a bit of paranoia, I'd kind of like to keep the staggered setup - but would like to go wider than stock on both rear and front. I'm craving less wind buffeting about, since I spend about 20 minutes on the highway each way, to and from work. It's hard to pull off the what-me-worry? look when being tossed about by a breeze. And powder coating my rims would cost a lot less than a new set of rims (Must. Have. Black. Rims.).
I see another post on another forum where a guy did this combo - it would mean I could move the rubber from back to front, and just buy tires for the back!
"175/55 front and 195/50 rear , on 15” rims"
