Need advice on TPS ASAP - Page 2 - Smart Car of America Forums : Smart Car Forum
Old 06-06-2008, 11:13 AM   #11 (permalink)
RussBarnes's Avatar
I sold one of the front tire/wheel/tps packages from mine and kept the other for spare. Bought two new rear rims and had all four powdered. Bought two new TPS from Tire Rack, I think $72 each. Installed in new rims, put new Michelins 185/60-15's on all four. Inflated fronts at 26, rears at 30, re set the TPS switch on the dash and all is well. I don't think these are rocket ships and all that sofisticated.
Old 06-06-2008, 12:34 PM   #12 (permalink)
randyzimmer's Avatar
Data I have is that they are sided F to R, L to R
I switched L to R on the front and the alarm continued to go off even after resetting the dash switch.
Old 06-06-2008, 03:01 PM   #13 (permalink)
Agent 86
Wizco's Avatar
I bought a set of take off wheels that came without the TPS. I ordered sensors from Flying Tiger, and installed 4 random sensors on 4 random wheels. Either I got incredibly lucky or it doesn't matter which one goes where. Not sure which.
Old 06-06-2008, 03:09 PM   #14 (permalink)
Agent 86
Wizco's Avatar
Originally Posted by saronian View Post
Note - The cost for 4 Tire Pressure Sensors as of June 2008
Flying Tiger $370
Tire Rack $253
And add $90 for ground freight from Flying Tiger.
Old 06-06-2008, 07:59 PM   #15 (permalink)
Fredvon4's Avatar
RandyZimmer.... I can tell you for a fact that they do not have any way to know where they are on the car.... if you just took off a Front right and left rim with no dismount of tire or air pressure change then you did not even need a reset...
I already took off, hand washed, hand waxed and deliberatly put back on opposit sides all 4 tire rim assys...no issue with TPS at all
Old 06-07-2008, 11:25 AM   #16 (permalink)
Can't explain it, just happened 3X until I switched L to R.
This frame has a different designation for each corner:
Old 06-08-2008, 06:02 PM   #17 (permalink)
mike-in-sa's Avatar
Maybe Randy's tps actually works.
Old 06-18-2008, 09:37 AM   #18 (permalink)
cubefx's Avatar
Thank you all!!!
Hey guys,
Finally got wheels back on the car. I believe that TPM location is irrelevant or I just got very lucky.
I mounted TPM sensors on the rims with torque wrench @ 8nm (thank you SmartCarGeek). Mounted tires with 28 PSI (both rear and front) just to make sure that sensors work. After driving for two minutes TPM light come up. Then I adjusted tires to the correct pressure (36 PSI rear/ 29 PSI front) and now everything works just fine.
Thank you.
CUBE
Old 06-18-2008, 10:56 AM   #19 (permalink)
Smart Car Geek's Avatar
It was my pleasure to help you Cubefx. Glad everything is working. Enjoy your new Smart in good health
Need advice on warranty - picking up soon! doogster smart General Discussion 11 05-21-2008 03:18 PM
Advice on dead battery lakelouie smart Operation and Maintenance 24 04-24-2008 06:07 PM
Need some sound advice smart bird Audio & Video 5 04-23-2008 03:53 PM
Against all advice mi_bumblebee New Members Area 13 02-27-2008 09:00 AM
Serious deal breaking cabrio flaw? call co asap mr_Cash smart News & Rumors 22 12-11-2007 08:32 PM
