When I saw that you went with the 205/50/15, I asked myself why I had gone with the (elsewhere suggested
New wheels/tires have transformed the car) 195/50/15. I thought that I would only get a close approximation of the stock outside diameter with my set up.
So I went to the tire dimension calculator and I got this info:
Totals are in inches (195/50), (205/50), (Difference)
Sidewall Height: 3.84, 4.04, 0.2
Section Width: 7.68, 8.07, 0.39
Overall Diameter: 22.68, 23.07, 0.39
Circumference: 71.24, 72.48, 1.24
Revs per mile: 889.36, 874.18, -15.18
If your speedometer reads: 65 You're going approximately: 66.13
All of this seems perfectly acceptable, and coupled with the extra rubber on the road, likely more desirable.
Good work. I think I'll go with the 205's on the next tire change.
This thread should probably be cross posted over in the
Smart Car Wheels & Tires - Smart Car of America Forums
