Rotate Side to side - Smart Car of America Forums : Smart Car Forum
Old 06-14-2009, 08:36 PM   #1 (permalink)
SmartDigger's Avatar
Rotate Side to side
I rotated my tires side to side today @ 5,000 mile. I will let everyone know how it works out. Anyone else doing this?
Old 06-14-2009, 08:49 PM   #2 (permalink)
sato7's Avatar
every one should rotate the tires off of the rims to put the inner side now to the outer side... that way you will wear the tires evenly... well more so.. our cars have very aggressive angles on the suspension to aide in handling. If you look at the car from behind you can see the tires look like /\ it helps corner better but eats your tires on the inside quite quickly.
Old 06-14-2009, 09:00 PM   #3 (permalink)
Owner for 3.8 years
Kermit's Avatar
My rears have worn evenly over the last 28,000 miles despite how it looks (negative camber). The fronts on the other hand......I flipped at around 25k.....trying to talk the wife into letting me get new rims with a good LRR tire.
Old 06-15-2009, 12:22 AM   #4 (permalink)
Originally Posted by sato7 View Post
every one should rotate the tires off of the rims to put the inner side now to the outer side... that way you will wear the tires evenly... well more so.. our cars have very aggressive angles on the suspension to aide in handling. If you look at the car from behind you can see the tires look like / it helps corner better but eats your tires on the inside quite quickly.
You're referring to the rear wheels but it's not the rear tires that wear unevenly, even though there is some negative camber. The wear is on the front tires that do not reveal camber when at a standstill. As suspension is compressed the camber changes and, because they are also the steering tires there is excessive wear on the inner portion of the tread. You're right that the only way to compensate for this is to re-mount the tires reversed on the rims. Changing from one side to the other will not help. That is the reason why the factory does not suggest rotating the tires.
Unfortunately, changing front to rear will help somewhat but with different sized tires that isn't possible. That is one reason why I installed the same sized tires on all four wheels (with suitable rims) - so that the wheels can be rotated front to rear.
Grey & Silver Side By Side And The 2009 Red Alan From New York smart General Discussion 8 01-03-2009 04:42 PM
PICS new red old red side by side Turbo42 smart General Discussion 24 12-10-2008 08:35 PM
Side Skirts CRC2362 smart General Discussion 5 10-27-2008 01:01 PM
From other side of the ocean... ruben farinha New Members Area 13 10-12-2008 05:04 PM
Side Skirts Derek Bell Archive/obsolete (?) threads 4 09-17-2008 11:47 AM
