rubbing in front with 17s? - Smart Car of America Forums : Smart Car Forum
Old 10-13-2009, 04:16 PM   #1 (permalink)
silverbrabus's Avatar
Finally tried swapping the Brabus rears to the front and driving it. Rubs at a high spot in the liner right next to the strut.
Did a search and read the threads. Looks like lowered with wider than 6.5 and more tire than 195 will rub up front.
Anybody that's rubbing any issues? Seems to be a body seam under the liner right where it's rubbing.
Old 10-13-2009, 04:58 PM   #2 (permalink)
For sale pm for details
Turbo42's Avatar
You would be rubbing on the spring perch to be exact. brabus wheels need a 3mm spacer up front. I have 7" wide rims up front and use a 10mm spacer with a 195 tire
Old 10-13-2009, 05:29 PM   #3 (permalink)
mrbadexample's Avatar
i'm thinking of going with 15x6 wheels and 195/50-15's all around, the car is not lowered. do you think there will be a problem?
mrbadexample is offline   Reply With Quote
Old 10-13-2009, 05:40 PM   #4 (permalink)
Turbo42's Avatar
No you will be fine
Old 10-13-2009, 06:59 PM   #5 (permalink)
GiantKiller's Avatar
My Schmidt Spacelines 7.5 front only rub on full turn(very little) and only after eibach springs settled.
Old 10-13-2009, 11:50 PM   #6 (permalink)
Not the perch, it is very close but won't hit.
Tire is rubbing plastic liner, but not at full lock like you might expect. Inside edge is hitting at the top at full strut compression.
Old 10-31-2009, 11:20 AM   #7 (permalink)
tbone28's Avatar
A small spacer should fix that...just make sure you have room on the outer fender, and don't end up rubbing there. If that happens, you'll need smaller tires
New Pics of Our Front Solid Aluminum Front Bumper BreathlessPerformance Interior & Exterior Styling 42 07-08-2009 07:37 PM
Front Spring Spacers to raise the front end to safe height after installing Lowering BreathlessPerformance Performance & Handling 4 02-26-2009 07:30 AM
need front rim hamillj Archive/obsolete (?) threads 5 11-10-2008 09:09 AM
need front rim hamillj smart Operation and Maintenance 3 11-09-2008 03:00 PM
Front lower air dam Derek Bell Archive/obsolete (?) threads 3 09-25-2008 12:56 PM
