Screw these euro vendors! - Page 3 - Smart Car of America Forums : Smart Car Forum
Trailer
Old 05-10-2008, 08:04 AM   #21 (permalink)
Supporting Tuner
Evilution's Avatar
Originally Posted by Frankenstein_Casanova View Post
After measuring a bunch of likely 16 and 17" wheels...
What wheel offset did you end up with, 35mm or 50mm?
Old 05-10-2008, 08:36 AM   #22 (permalink)
Fredvon4's Avatar
Thanks Kane!
You just saved me pulling a hub to see exactly what your photo shows and the obvious bosses... koool..... adapters it is
Who is the unsprung weight worry wart up above and why would you think a pound or less of aluminum adapter makes any significant difference...
The very worst case increase of any unsprung weight is easy to manage with progressive rate springs and shock absorber compression and rebound rates
I am seriously considering 4 corner full adjustable coil over sets and camber adjuster elliptical bolts for the front struts
I also plan 100~125 HP... oh dang there goes the worthless warranty... on the motor and trans only....
Old 05-10-2008, 10:08 AM   #23 (permalink)
Supporting Tuner
Evilution's Avatar
The only possible damage the extra weight will do is increase the wear rate of the bearings but then putting anything larger on will do that.
The fact is that the wheel bearings are actually quite cheap and take about 20 minutes to fit all 4. Well worth the time out for beefy looking rims.
I ran adapters on my 450 for years with no problems. As long as you check the bolt torque every few thousand miles you'll be ok. The only thing that put me off was the need to have 3 or 4 tools to remove the wheel and adapter incase you needed to fit a spare standard wheel.
Old 05-10-2008, 11:10 AM   #24 (permalink)
I was afraid the hubs were like that. Very similar to the old vws.
Smartbillet is offline   Reply With Quote
Oil Drain Screw and Passenger Seat-Warranty plan Markie smart Operation and Maintenance 3 05-12-2008 12:18 AM
Do all vendors have to pay? Harleyduo smart General Discussion 7 11-21-2007 04:57 AM
Supporting Vendors? jwight smart General Discussion 2 11-16-2007 10:17 AM
Time for Vendors to get with it! Harleyduo The Car Lounge 8 11-09-2007 07:40 PM
Early Vendors where are YOU? Harleyduo smart General Discussion 7 10-17-2007 07:13 PM
