something to keep in mind....WEIGHT!
when going from a 175 to anything larger, you're also increasing the WEIGHT at each wheel. while 5, 6, or even 10lbs may not seem like alot, when you factor in the total weight of the car, the weight of the OEM wheel and tire combination, you're adding stress to the drivetrain, not to mention brakes.
just something to keep in mind, like i said. if you watch your 'weight' of your tires, you should have no problem.......
