Originally Posted by jonnysan
In the wheel diameter and that is what dictates rpm's of the wheels. Both wheels, although different aspect ratios in stock form, measured 22 1/2" diameter so the ESC/ABS target sprocket will always turn the same speed and have no effect on either's proper operation.
Thank you.
Tire Rack's site shows diameter of 22.3" and 859 revs/mile for the 155/60/15's and 22.6" and 895 revs/mile for the 175's. It's very close, and on a non ABS/ESC car I wouldn't have hesitated to make the change.
What I wanted to confirm is that in the real world it was close enough not to get the smart's ECU all worked up over the difference. I take it you're not having an issue.
Dan
Who's looking to dial out a little bit of understeer.
