Smart vs. Pothole... - Smart Car of America Forums : Smart Car Forum
Old 09-19-2008, 01:10 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
MCMarathoner's Avatar
I nailed a pothole last weekend - results below. Also, the shock broke the headlight from it's mounting - another $264 plus labor. FYI, tire and wheel warranty does not cover the sensor ($101) or taxes. Oddly, the wheel didn't apppear damaged from the visible side.
Be careful while happily motoring
26.2
MCMarathoner is offline   Reply With Quote
Old 09-19-2008, 01:18 PM   #2 (permalink)
i wonder how many smart dealers, when they were pushing the tire and wheel warranty on their unsuspecting client, reminded that client that taxes and the $100 sensor would not be covered by the warranty?
my guess. zero.
Old 09-19-2008, 01:21 PM   #3 (permalink)
yes, but...
my guess. zero.
The cost of the warranty was covered with one mishap. My brother insisted that I take the warranty - I've never had to use a warranty before so this one was welcome. Freewheeling from now on pun intended...
Best,
26.2
Old 09-19-2008, 01:23 PM   #4 (permalink)
DFWehman's Avatar
How deep / wide was the hole? Your speed? (Don't care about posted speed!)
Old 09-19-2008, 01:33 PM   #5 (permalink)
Yeah, I'd like to see a pic of the the winner of this contest.
Old 09-19-2008, 01:38 PM   #6 (permalink)
DFWehman's Avatar
Hi Suze! Looks like it took a real whack in a sharp hole. You have to compress the tire, then deform the rim to the point where it fails. I know it happens, and there is a lot of force on the wheel, but I'd hate to see the factory wheels failing. Since (I believe) this is the first post, I won't start screaming for a RECALL just yet!
There's a small pothole I must hit every morning. Easy enough to avoid, but, Noooo, bump-bump every day. I'll learn some day! (Maybe I'll fill it in with fast set concrete!) (not..)
Old 09-19-2008, 01:45 PM   #7 (permalink)
Is it just me, or does that wheel look pretty thin all the way around compared to other alloys. I think the metal used in our Mini 12 inch alloy wheels is thicker than that.
Old 09-19-2008, 01:52 PM   #8 (permalink)
DFWehman's Avatar
Could be the angle of the break & photo, can't tell. I'm curious how hard it hit. Assuming its a front, that was probably a pretty wild ride. You'd have had to be pretty quick to notice the pressure loss sensor alert!!
Old 09-19-2008, 01:58 PM   #9 (permalink)
We're looking at the back side of a stock rim, right?
- I avoid ALL bumps and potholes - even try to drive around manhole covers when I can. Sometimes just the crosswalk paint can give you a pretty good jolt!
Old 09-19-2008, 02:16 PM   #10 (permalink)
DFWehman's Avatar
Yeah, that's the back. Bet the air came out fairly quickly... Must have lost a few fillings in his teeth!
LinkBack to this Thread: http://www.smartcarofamerica.com/forums/f64/smart-vs-pothole-14069/
All Cars, All the Time: Pow! smart fortwo Takes It In The Wheel! This thread Refback 09-20-2008 10:34 AM
