I hate to keep referring to this web site, but
www.yarisworld.com has a fair amount of info on this subject. It seems some wheels are worse than others, as more of the weight is located towards the outer perimeter of the wheel (for aesthetics), which makes acceleration worse. I imagine this is a bigger issue with stop & go city driving vs. highway, constant-speed type driving. I do know that the general consensus (based on data) over there is that bigger wheels are worse than smaller wheels. If you want to maximize MPGs (and save money on new wheels & tires), stick with the smaller ones. Stay away from 16 & 17 inchers - way too much weight and rotational mass way out there on the outer radius. But as one hypermiler there said, it would be a waste of money replacing what you already have with something lighter, as you would never recoup that money in MPG savings. Replace them for appearance, but note simply to save gas. Still, do the research first and make informed choices. That's what I'm trying to do.
And Tirerack has a report on a test they did with various weight wheels re handling. Turns out that the lighter the wheel/tire, the better. So there is a performance dimension to this as well.
Macaw, I think a couple of people around here were weighing their cars which had different options, which is at least a start. Still, I'd like to see a more comprehensive treatment of the subject. Yaris people yank back seats for weight savings (and weigh them when they do), for example, but we don't have much to yank in a Smart, and Smart owners don't seem to be as obsessive over the MPG thing for some reason. Still, I haven't seen a comparison of the weight of a stock Pure (okay, with AC) and a stock Passion and a stock Cabriolet.
And surely someone has pulled their steel wheels and could throw a couple on a scale? A dealership out there?
Always hoping.
Jeff
Originally Posted by geosynch
One thing I have never seen discussed is rotational inertia. Since the wheel rotates, this is important and since inertia is a function of mass and the distance of that mass from the axis of rotation, not all 25 pound wheel/tire combinations will be the same.
I suspect that for a given wheel diameter there isn't a huge variance, though, and that could be why it isn't discussed. But I also suspect on a car this little, a little bit of variation can have a significant affect on performance (not just 0-60 times, but also on mileage).
I would really like to hear from someone knowledgeable on the subject to tell me what the difference is in the rotational inertia of a 15 inch wheel/tire and a 17 inch wheel/tire and how that might impact performance.
geosynch
