Strange Tire Pressure - Smart Car of America Forums : Smart Car Forum
Old 06-10-2008, 08:33 PM   #1 (permalink)
sixcrows's Avatar
This morning, I noticed the tire pressure sensor light was on. The ride felt fine. At the first stop sign, I hopped out to take a quick look. Everything seemed fine. When I got to work, I looked for nails or screws in the tires. Nothing.
Now, I had just checked the tire pressures a little over a week ago, and they were all set to the standards listed on the door label.
I cleared the light and on the way home it popped on again. I finally got out the tire pressure gauge and found that each tire had oddly differing pressures. The back tires were HIGHER than I had inflated them to last week by almost 5 psi.
The front tires were another story. The right tire was 2 psi over, and the left tire was 7 psi over. What the hell?
Can the VERY hot and humid weather here in the Albany/Schenectady/Troy area of New York State have affected the tire pressure?
Since I balanced out all the numbers, the warning light has stayed off.
What the hell happened?
sixcrows is offline   Reply With Quote
Old 06-10-2008, 08:38 PM   #2 (permalink)
What you said!! Temperature and humidity will have an effect on tire pressure, but unless there is a leak, it should be proportional. I would check pressures daily, at the same time of day or more appropriately, the same temperature. The tires should not have been run on before checking. Let us know what you find.
Old 06-10-2008, 08:45 PM   #3 (permalink)
Lgaruti's Avatar
Yes! Because the tires are small in size and hold very little air volumn they will react to temp changes with greater swings than your typical larger vehicles.
Lgaruti is offline   Reply With Quote
Old 06-11-2008, 11:46 AM   #4 (permalink)
Senior Smartie
jonnysan's Avatar
Left side of the car was facing towards ....
The sun on the day you checked the pressures. We've had some pretty intense heat here in Albany for early June....
Old 06-11-2008, 01:15 PM   #5 (permalink)
Nicholas's Avatar
Another reason for nitrogen fill...not the great pressure swing here in Florida.
Old 06-11-2008, 01:24 PM   #6 (permalink)
it's great if you're in the business of selling nitrogen!
Old 06-11-2008, 05:11 PM   #7 (permalink)
Senior Smartie
jonnysan's Avatar
This has been discussed before, but....
I have to comment on this one.
Nicholas....ALL gases EXPAND when heated bar none. The air used in a tire has only 20% less N2 concentration than "4- 9's" N2 from a bottle along with a slight amount of water vapor if the air isn't dried...not enough advantage to say so in my opinion and surely not worth what they will charge for it....that's a fact Jack.
Keep your life uncomplicated....use AIR!
Old 06-11-2008, 07:07 PM   #8 (permalink)
Nicholas's Avatar
Understand the reasoning...using 95% nitrogen that has been ran thru a dryer system. Just my liking...Thanks anyway!
Old 06-11-2008, 07:09 PM   #9 (permalink)
Soooo..sixcrows!! What have you found?
Old 06-11-2008, 08:51 PM   #10 (permalink)
sixcrows's Avatar
I've checked the pressure twice daily past two days. No change in pressure.
All seems OK. I don't know how I got 4 very different readings the other day.
So my tire pressure light went on this morning.... bottlerocket smart General Discussion 2 05-01-2008 05:54 PM
Tire Pressure Sensor Okie Boy smart General Discussion 17 04-10-2008 07:12 PM
Wheel removal - tire pressure sensors Capt. Jack smart Wheels & Tires 5 03-25-2008 06:09 AM
Tire Pressure Warning came on today SmartyPants25 smart Wheels & Tires 7 03-02-2008 09:59 AM
Wrong tire pressure gusfraga smart Wheels & Tires 30 01-27-2008 05:38 PM
