Originally Posted by sixcrows
... What the hell? ...
Working back to the origin of the thread, and all that has followed, I would recommend that a smart owner invest (yup, "invest") in a good, reliable, consistant, bullet-proof pressure gauge. The cheap pencil-type gauges with a marked rod that squirts out of the end are notoriously inaccurate. A lot of the small dial-type gauges are not much better once they have been knocked-about.
Considering how much a smart's comfort and handling is affected by tire pressure, I can recommend after my own use of a "0-30," the INTERCOMP 0-60 psi, dial gauge with a pigtail and bleed-off valve (or the equivalent if you can find one). $35 well spent - truely pro-grade.
Pegasus -Tire Pressure Gauges 0-60psi
