Old 09-11-2008, 10:27 AM   #1 (permalink)
BigGoofyGuy
BigWarpGuy's Avatar
Drive: Smart Fortwo Pure
Tire caps?
The low tire pressure indicator went on. I went to see which one was low. One of the caps for the tire 'connector' (when filling the tire with air) was gone. Are these unique or do I can I use regular ones? I do not remember the name of the piece.
Old 09-11-2008, 10:30 AM   #2 (permalink)
Valve stem caps or covers; any standard ones should work. Your smart center can get replacements ($99 deposit, 18 month wait, however.)
Old 09-11-2008, 10:38 AM   #3 (permalink)
BigGoofyGuy
BigWarpGuy's Avatar
Thank you for the information. I will check the local auto parts store. Perhaps they might have some fancy ones.
Old 09-12-2008, 12:57 PM   #4 (permalink)
BigGoofyGuy
BigWarpGuy's Avatar
I do not know if it fell off or if it was taken off. Would not having a cap cause the air pressure to go down? Would tire pressure decrease even though I had the little car since March of this year? I will look for a replacement. I found some interesting ones on Froogle.
I found one which indicates the tire is low on pressure. The inside indicator indicates a tire is low but not which one.
CAMEL TIRE INDICATING VALVE CAPS, 36 PSI RANGE, 4 PER PKG. (38-710-4)
Old 09-12-2008, 01:14 PM   #5 (permalink)
BigGoofyGuy
BigWarpGuy's Avatar
I found some locking stem caps. It would be nice if the Smart logo was available on one.
Old 09-12-2008, 02:09 PM   #6 (permalink)
giffSCPA's Avatar
Drive: 2007CLS550;2008smart CAB
smart logo valve caps--
Permalink Reply by classicsmarts on May 13, 2008 at 6:53pm
smart Chrome Logo Valve Stem Caps
Pretty cool little caps. $13.60 for the set. Please call me (Paul) if you'd like them. 512-844-3266 smart center RR
giffSCPA is offline   Reply With Quote
Old 09-12-2008, 02:09 PM   #7 (permalink)
CruisingAZ's Avatar
Drive: 2008 smart passion
Old 09-12-2008, 02:10 PM   #8 (permalink)
Drive: HONDA RIDGELINE 2006
The only valve caps that should be used on tpms valve stems should be plastic only because metal caps interfer with the signal coming from the tps inside the tire and wil cause problems with tire pressure monitoring system.
JIM VINYARD is offline   Reply With Quote
Old 09-12-2008, 02:15 PM   #9 (permalink)
That's odd, I'm pretty sure the ones Paul sent me (with the Smart logo, sold by Smart) are steel. I'm had them on for a couple thousand miles and never noted a pressure monitoring problem. But, then again, I do check the pressures pretty regularly.
Old 09-12-2008, 10:07 PM   #10 (permalink)
Don't use these. If the cap is mishandled or if you crack the clear plastic tip by curbing or etc, they will leak. Remember you don't have a spare tire.
Where can I get chrome mirror caps cheap? mnext02 Smart Car General Discussion 5 07-03-2008 06:03 PM
Chrome Grille & Side Mirror Caps For Sale cmjars Smart Car Parts Marketplace 8 06-16-2008 08:48 PM
