Tire Stuff - Smart Car of America Forums : Smart Car Forum
Old 11-23-2007, 05:21 PM   #1 (permalink)
Tire Stuff
Notwithstanding the apparent problem in the UK with obtaining replacement tires for the 451, the two OEM sizes are both currently in stock in the US, at least at the Tire Rack (http://www.tirerack.com/):
155/60R15 - Continental ContiProContact (Grand Touring All-Season)
175/55R15 - Continental ContiProContact (Grand Touring All-Season)
and,
Continental ContiEcoContactEP (All-Season)
I know that the standard protocol for a flat (smarts carry no spare) is to inject the tire with the provided can of some "goop" or " slime" or something, then inflate it with the 12V tire pump. Well, the pump is OK, but I'm not that taken with the goop. It seems to me to be a bit "hit-or-miss," and I don't know what it would do to tire balance. If the wound allows, I would opt to first to use a plugging kit (a clearing rasp, plugs, insertion tool, plugs and cement). It is usually a permanent and safe fix. Of course, that routine will likely involve an additional jack and lug-bolt wrench, but those are available.
Old 11-23-2007, 06:09 PM   #2 (permalink)
spdickey's Avatar
...If the wound allows, I would opt to first to use a plugging kit (a clearing rasp, plugs, insertion tool, plugs and cement). It is usually a permanent and safe fix. Of course, that routine will likely involve an additional jack and lug-bolt wrench, but those are available.
Difference seems to be between a temp fix that would get you a few hundred miles with the go-flat stuff, and a permanent repair job. Not sure most of us will be cleaning, plugging and cementing our tires along the roadside. I'll be happy to drive to the nearest Big O to get a flat repair.
Old 11-23-2007, 06:21 PM   #3 (permalink)
Smart A**
lhoboy's Avatar
.., but I'm not that taken with the goop. It seems to me to be a bit "hit-or-miss," and I don't know what it would do to tire balance.
I have my concerns about this as well. The excess goop in the tire will have a tendency to settle and pool and dry into a lump in the tire, leaving the tire out of balance. If used as a temporary fix, I would have the tire shop break the bead and wipe out the slime before the complete the permanent fix. Fixing from the inside is a better repair anyway.
Old 11-23-2007, 06:35 PM   #4 (permalink)
The plugging operation can be completed roadside in about five minutes once you remove the tire, find the culprit (nail, etc.), and pull it out. Obviously, if the problem is a shoulder puncture or sidewall cut, no goop nor plug will do you any good, nor any Big O repair. And you are not going to be driving to the nearest Big O on that sneaker. But a plugging kit (as little as $5) is a good first shot, even if you ask the AAA (or Penske) guy to do it.
Old 11-23-2007, 07:26 PM   #5 (permalink)
Once the tire is inflated with the goop you need to get driving so it is evenly distributed throughout the tire keeping it in balance. So it says on a can of "Fix-A-Flat".
Old 11-23-2007, 07:59 PM   #6 (permalink)
Gortok's Avatar
Fact is, you don't necessarily have to take the tire off the car to plug it. Usually, you can slowly roll the car until you see the nail/screw. Then, you can use the weight of the car to hold the tire still to plug it.
Fix-a-flat, in my professional opinion, should be outlawed. It should only be used to inflate a tire in a last resort. The stuff is flammable and a low tire builds up a lot of heat. Not to mention, if you take a hard turn and the tire pops off the rim, a steel rim could spark a fire/explosion.
The stuff is virtually impossible to clean out of a tire which will make a proper, in-tire patch repair unlikely.
Old 11-23-2007, 09:15 PM   #7 (permalink)
DaveInTexas's Avatar
Check the can...
Certain brands of Fix-o-flat are flamable as they use propane for the inflation. Others brands specifically say they are not flamable.
DaveInTexas is offline   Reply With Quote
Old 11-24-2007, 08:13 AM   #8 (permalink)
Fredvon4's Avatar
I sat waiting for a tire repair once and read a poster in the shop about "fix a flat" stuff and how the repair guy needs to know if there is any in the tire before attempting dismounting...
the caution was because the steel removal tools can cause a spark potentially maiming or killing the repair person... The poster was complete with pictures and not something to see before lunch
That caused me to stop using the crap...
Yes, there are non flammable versions for sale but who reads that fine print in the store?
I ONLY use green slim or other goop in lawn tractor tires...
Years ago in Germany I did a side of the road repair on a motorcycle tire with "fix a flat" my wife brought out to me from home. I nearly wrecked because of the severe imbalance on the front tire when I merged back onto the autobahn... not good and totally unexpected that first time.... got a new front tire that day
I don't think there is any danger of the current brands going "solid" over time...However I know in very cold weather they can take a long time to flow properly and spin balance from the centrifugal force.... well any way on my sons hunting 4wheeler they are bad out of balance for nearly a mile because of this phenomenon
In Europe, and I suppose if we looked here, there is a professionally installed tire sealer that once properly installed is spin spread and then turns semi solid adhesion to the inside of the tire. The stuff remains gooey enough to flow into a puncture and seal fairly large sized wounds.
I don't intend to use any of these methods with mine...
I will watch locally and e-bay for "take offs" for cheap and get a set. Probably take one along for any long distance trips out of my local area.
My giant F350 factory rims are over $450 each and the tires usually in the $200 range... because so many people buy new rims and tires to get away from the factory stuff I usually can find new zero mile "take off" tire and rim assemblies for under $100 each... my current truck with 50K miles still has 3/4 tread on all the tires due to rotation of 8 in the mix...
I already know I want different rims so I may end up with 12. The factory set, a set of take offs, and some day the rim/tire combo I really want. Properly rotated, I should get a very long life span out of them
Old 11-24-2007, 10:57 AM   #9 (permalink)
sisyphus's Avatar
Many smarties in other parts of the world acquire a front "steelie" with a front tire and keep it behind the seat as a spare. It will work just fine even on the rear axle, but should not be used long term in that position. Have a small tire cover made for it that matches your interior and it will look like it's supposed to be there!
I agree, I don't like the goop!
sisyphus is offline   Reply With Quote
Old 11-24-2007, 12:06 PM   #10 (permalink)
pokeyrider's Avatar
What about Run-Flat tires?
pokeyrider is offline   Reply With Quote
Smart car spare tire smartcar smart Wheels & Tires 50 06-27-2009 06:56 AM
Any wheel, tire, suspension changes planned? Fredvon4 smart Modifications 23 02-24-2008 05:13 AM
Mr. Toad goes down in flames... a reminder to check tire pressure? The News Reporter The Car Lounge 1 08-16-2007 05:41 AM
What after-market stuff would you like to see? shack01 smart Modifications 17 08-13-2007 10:03 AM
