Old 04-15-2009, 12:31 PM   #1 (permalink)
JimDantin's Avatar
Tires for Genius 15" wheels.
I've mounted the OEM 175/55-15 rear tires on my Genius front wheels, and a pair of 205/50-15 Goodyear Eagle GT-HR on the rear. This combo looks good and handles well.
When the time comes to replace these tires, I want to be ready to move up to some larger tires. Do any of you have larger tires mounted on 15" Genius rims? I'd like to find the set of staggered tires in the same brand.
Old 04-15-2009, 12:40 PM   #2 (permalink)
sato7's Avatar
Drive: 451, rav4, mazda6
how wide are your front wheels?????.... rears???
I'm running 6.5" 15s all around with stock rear tires.. all around.
Old 04-15-2009, 12:45 PM   #3 (permalink)
JimDantin's Avatar
The fronts are 5.5 and the rears are 6.5
Old 04-15-2009, 07:35 PM   #4 (permalink)
mismart's Avatar
Drive: '08 /Smart Cab/'08 Jeep GC
I have genius 15 x 6.5 all around. I used Yokohama S-Drives,205/50 on the rear and 185/55 on the front. They are working great - excellent grip, quick steering, reduced cross wind effect, and improved ride compliance. A side benifit is that I've maintained the OEM stager front and rear, just added 30mm width on both ends.
Several people have used 195/50 on the front, but that strays from the OEM diameter, but the 185's just came available and will work on your 5.5 front rims.
I'm also using a full Brabus suspension kit - new springs and Bilstein shocks and struts. It's made a new car.
mismart is offline   Reply With Quote
Old 04-15-2009, 08:39 PM   #5 (permalink)
das Auto
rolly's Avatar
Drive: 2009 white Wabbit
Fit
Yokohama S.Drive - 195/50R15 - 82V - BW on 15" Genius 6.5" wheels Front
Yokohama S.Drive - 205/50R15 - 82V - BW on 15" Genius 6.5" wheels Back
rolly is offline   Reply With Quote
Old 04-16-2009, 05:33 AM   #6 (permalink)
JimDantin's Avatar
mismart -- Great info on the Yoko 185/55. That looks like the matched set I've been looking for, but they're SUMMER tires! I really need all-season.
So -- anyone know of an all season tire offered in both 185/55-15 and 205/50-15?
Or, what about a bit larger diameter set -- since my speedo reads about 6-7% fast, I could easily go to a taller tire if it didn't rub.
Old 04-16-2009, 05:35 AM   #7 (permalink)
JimDantin's Avatar
rolmeister -- since the tires are slightly different diameters, does the computer think you're having traction problems?
Old 04-16-2009, 10:29 AM   #8 (permalink)
SubSlr88's Avatar
Drive: 04 Murano 08 Passion Coupe
Hmmmm - the stock tires are different diameters. It can't make any difference since that is a stock Brabus setup IIRC.
And isn't your current setup of differing diameters??
Old 04-16-2009, 03:27 PM   #9 (permalink)
JimDantin's Avatar
No, they are actually very close -- likewise the Brabus setup. Run the numbers through one of the online tire size calculators. i like this one:
Tire size calculator
Old 04-16-2009, 06:48 PM   #10 (permalink)
sato7's Avatar
For now I have the all black genius 15s by 6.5 all around running the 175/55/15 OEM tires... its what the budget allowed for now but soon I'm getting more meat on those rims... so you guys say 195/50/15s will fit-not rub-work up front? I have OEM suspension and don't think I'll be stiffening that up. it's already too bouncy if anything I think the shocks need to be upgraded but not the springs stiffened....
16" or 17" wheels and tires? lowndex Smart Car Modifications 3 12-27-2008 01:06 PM
17" Wheels, Tires, adapters starting @ $1,449! SmartMadness Vendor Marketplace 30 12-26-2008 06:12 PM
15" Stock wheels and tires SunDiego Smart Car Parts Marketplace 10 12-08-2008 09:28 PM
A change to 16" wheels & tires really improves the ride lowndex Smart Car Wheels & Tires 22 07-04-2008 08:29 AM
For sale - stock alloy 15" wheels and tires. lowndex Smart Car Parts Marketplace 0 06-01-2008 05:27 PM
