Old 02-25-2009, 06:09 PM   #1 (permalink)
Drive: smart Fortwo
torque specs
Anyone know the torque specs for the tpm sensors? And while I am at it the wheels?
Old 02-26-2009, 10:03 AM   #2 (permalink)
moderator
Dunerunner's Avatar
Drive: Yellow/Black Passion
Torque Specifications:
Lug/Wheel nuts - (24mm hex)
81 ft/lbs
Oil Filter - 14Nm (10.3 ft/lbs)
Oil Sump nut (Drain Plug) - 65Nm (48 ft-lb)
Don't have anything for TPMS but I believe it was in one of the wheel swap threads somewhere.
Old 02-26-2009, 11:55 AM   #3 (permalink)
SylenThunder's Avatar
Drive: Smart Passion Coupe
I found this on the Hanco site...
  • On vehicles with tire pressure sensors within the wheel, sensor nut and valve cores must be torqued to specified inch pounds.
Cores must be at 0.13 - 0.27 ft. lbs. (0.17-0.37 N.m).
Found other sites that specified 1/4" Inch Pound for the correct torque
Old 03-01-2009, 07:17 AM   #4 (permalink)
Drive: smart Fortwo
Thank you for the help. I read thru posts and cube states 8nm .tire rack told me 4nm which translates to 35.4 inch pounds.I did not mount the tires yet.but good news I found a cheap source of tpm sensors. It was confirmed by Tire Rack but since I have yet to mount them can't personally confirm it.
oh the source is cheaper than tirerack.
Exhaust manifold torque? GHammerly Smart Car Modifications 2 10-25-2008 02:12 AM
Lug nut / bolt torque partsrme928 Smart Car Wheels & Tires 11 09-27-2008 12:51 AM
UK smart specs jwight The Car Lounge 3 08-10-2008 05:00 PM
Radio 10 Specs ck_az Audio & Video 1 06-01-2008 07:33 PM
451 Specs lhoboy smart fortwo (451 - US vehicle) 15 10-10-2007 07:54 PM
