TPMS - Smart Car of America Forums : Smart Car Forum
Old 10-20-2009, 12:00 PM   #1 (permalink)
TPMS
Do all the TPMS out there that fit the smart have the same mounting nuts and washers? I guess what I'm asking is are all the TPMS interchangeable?
smartah is offline   Reply With Quote
Old 10-20-2009, 12:23 PM   #2 (permalink)
The internal mounted units are not all the same. They're interchangeable in that they all mount in the stem hole of the rim and include the integral stem with all mounting hardware.
I'm not sure what your question is looking for.
Old 10-22-2009, 09:35 AM   #3 (permalink)
What I'm asking is twofold;
If a TPMS is taken off a wheel that I have already and put on a different wheel, does anything need to be replaced? Washers? Nuts? Core? Or can I just swap the TPMS?
If a replacement TPMS is purchased would mounting hardware for that particular TPMS be needed? Are all mounting hardware interchangeable?
Old 10-22-2009, 09:52 AM   #4 (permalink)
IMO- just put rubber stems in and delete the TPMS. I can't tell you the number of problems I've come across with TPMS sensors.
Anchorman is offline   Reply With Quote
Old 10-22-2009, 10:33 AM   #5 (permalink)
WhiteNBlack08's Avatar
Once you take them off, your supposed to buy the install kit, which usually contains the rubber seals, and a new nut. Supposedly, when you remove the sensor, the seals are no longer any good. I have not personally removed any, just what I've read.
Old 10-22-2009, 02:01 PM   #6 (permalink)
Yes that's correct, you need new service packs each time the sensor is removed and reinstalled - and you must torque the stem on to specific specs. There are other considerations you need to know about as well. Special precautions must also be taken during wheel removal and installation. This is not just a bolt and forget installation nor is it something for a DIYer to be doing.
Here are some references that might be helpful.
TPMS from Bartec USA
The following video can alert you to some of the issues and requirements.
There are other videos on the subject of training that can be helpful.
Tire Tech Information - Tire Pressure Monitoring Systems
Old 10-22-2009, 02:45 PM   #7 (permalink)
Brabus007's Avatar
When I had two new tires put on the Rear Rims that I was putting on the front of my Smart at "Discount Tire Company Store" they used New TPMS Seal Kits ~ $7.00 each to certify their Tire work (they took the TPMS's out of the front tires and remounted the fronts with rubber valve stems so I would have the fronts for Spares)
Brabus007 is online now   Reply With Quote
Old 10-22-2009, 06:25 PM   #8 (permalink)
SmartDigger's Avatar
I picked up 4 kits from tire rack for when I swap out my OEM rims for new ones
Old 10-22-2009, 07:30 PM   #9 (permalink)
FWIW, RussBarnes and Cube have both re-used theirs: (Removing TPMS sensor)
But, that was before you could find the things, so I think all would now recommend replacement.
Old 10-23-2009, 09:51 AM   #10 (permalink)
kurt013's Avatar
I purchased two rear wheels for the front of my Smart and had the old TPMS taken off the fronts and installed on the new wheels. One worked just fine, and the other kept losing air. I went to Discount Tire and they installed a new seal on the problem wheel for around 5 or 6 bucks. I would guess my success rate of 50% is about average. For a few bucks the new seal is worth doing when you change tires.
kurt013 is offline   Reply With Quote
How Do I Know? (Re: TPMS) jdlynch99 smart Wheels & Tires 26 11-12-2011 07:21 AM
Tpms mia......... Godfather smart Wheels & Tires 16 04-12-2010 09:27 AM
Disable TPMS? Possible? theSMART1 smart Wheels & Tires 1 10-15-2008 12:04 AM
TPMS issue Trena smart Wheels & Tires 14 10-01-2008 10:26 AM
TPMS needed... Nicholas smart Wheels & Tires 0 09-11-2008 06:08 PM
