Turn off TPM Light - Smart Car Forums
post #1 of 11 (permalink) Old 01-10-2011, 05:51 PM Thread Starter
tgobie50's Avatar
Quoted: 6 Post(s)
Turn off TPM Light
Anyone know if its possible to disconnect the TPM light. I've been having lots of prombles with the TPMs, flat tires, light flashing and nothing wrong with air pressure. I'm getting rid of the TPMs and would like to disconnect the light.
Thanks
tgobie50 is offline
post #2 of 11 (permalink) Old 01-10-2011, 05:56 PM
Quoted: 607 Post(s)
Get some electrical tape.... The dealer will not shut off the light as it is part of the safety system.
jimvw57 is offline
post #3 of 11 (permalink) Old 01-10-2011, 05:57 PM
Quoted: 160 Post(s)
..black electrical tape...if you must...
...but Why?...you are already experiencing "flat tires"...without the warning by the time you start to feel the pull/leaning/dragging of a flat tire the damage to the rubber it's done and possibly the rim...
jetfuel...but...what do I know
jetfuel is offline
post #4 of 11 (permalink) Old 01-10-2011, 06:58 PM
Quoted: 607 Post(s)
I hear ya Jet... I put sensors in my snow tires just so I would avoid just that problem.. Assuming the O.P. is out of warranty, he might want to talk to a tire shop. I believe they have a device that can check each individual sensor to pinpoint the one with the problem. Sensors can be purchased from Tire Rack for around $40 ea.
If the tire pressures are too high, it can cause sensor errors. I am sure you have done this but it has to be asked: You set tires to the correct pressure and held down the reset button until the light quit flashing , right?? Also use a digital gauge and NOT one of those flakey pencil type gauges from the local convenience store that they let you borrow (they are never correct)
I went crazy using 3 different pencil type gauges, none of them were correct. I used a digital one and problems went away.(about 20 bucks)
jimvw57 is offline
post #5 of 11 (permalink) Old 01-10-2011, 07:23 PM Thread Starter
tgobie50's Avatar
Quoted: 6 Post(s)
Thanks guys, I totally understand the operating of the TPMs. My problem is that they have been leaking, I've rebuilt them, the air pressure is right.
It's just something I can do without, been driving a long time and don't like the BS that goes along with some of these high tech gadgets. Some are good, some are just a pain in the ass. I'm gonna pull the dash and see whats up.
tgobie50 is offline
post #6 of 11 (permalink) Old 01-11-2011, 08:06 AM
ZigZag's Avatar
Quoted: 9 Post(s)
That's what we did, just cut a half inch piece of black electrical tape and put over the light and problem solved.
ZigZag is offline
post #7 of 11 (permalink) Old 01-11-2011, 08:12 AM
BARNEY O's Avatar
Quoted: 123 Post(s)
Jim, might check that price on TPS's at Tire Rack ( much higher now)
I just bought a set @ Discount Tire for $48.00 ea.
BARNEY O is offline
post #8 of 11 (permalink) Old 01-11-2011, 11:34 AM
Quoted: 607 Post(s)
September 2010 I bought 4 sensors with my snow tires and was charged $40 each. I have the invoice. They may have gone up since then.
jimvw57 is offline
post #9 of 11 (permalink) Old 01-11-2011, 03:17 PM
badwolf's Avatar
Quoted: 6 Post(s)
I have bought another set of rims and tires for summer without the TPM's. This is the first car I've had with that system and I find it unnecessary ...because I check my pressure a couple times a month. If I can find a way to disable it tgobi50, I'll let you know.
badwolf is offline
post #10 of 11 (permalink) Old 01-11-2011, 03:55 PM
kheran's Avatar
Quoted: 197 Post(s)
If need be, Tom, you could go to the Evilution site and find the mods for changing the LED colors and just maybe remove the LED for the TPMS. Just a thought. it's a little more permanent than electrical tape.
kheran is offline
Human Verification
Plastic in TPM? Leelee smart Wheels & Tires 19 08-20-2010 11:32 PM
Stop & Turn Signal Light Lkruchten smart Operation and Maintenance 2 03-21-2010 04:58 AM
Rear Right Brake/turn light not working bumblebee smart Operation and Maintenance 5 01-17-2010 08:53 PM
Wow! TPM really works. fpage77 smart General Discussion 4 03-21-2009 08:08 PM
help? (Re: mismatched TPM) 16.luca smart Wheels & Tires 5 02-14-2009 04:55 PM
