Old 06-11-2009, 06:05 AM   #1 (permalink)
gusfraga's Avatar
Drive: smart 451 cabrio
Uneven wear in front tires
My smart has 16000 miles and today I've noticed uneven wear on the front tires wearing from the inside of the front tires.
pics
http://www.smartcarofamerica.com/gal...2/imgp0003.jpg
http://www.smartcarofamerica.com/gal...2/imgp0008.jpg
http://www.smartcarofamerica.com/gal...2/imgp0002.jpg
Any ideas?
Is this issue cover by the warranty?
Any help will be appreciated
regards
Gus
Old 06-11-2009, 06:07 AM   #2 (permalink)
Boosted!
babybenz's Avatar
its normal alot of people are seeing the same thing swap the tires from side to side every 7500 miles
Old 06-11-2009, 06:11 AM   #3 (permalink)
gusfraga's Avatar
Hi
side to side swapping wont solve the problem because the wear is from inside out.
Gus
Old 06-11-2009, 06:12 AM   #4 (permalink)
Gobble Gobble
Hey Baby Benz, How does that help? I thought you needed to swich them inside out on the rims to extend the life.
Old 06-11-2009, 06:17 AM   #5 (permalink)
Boosted!
babybenz's Avatar
nope mine were feathering on the inside my tech here swapped them side to side problem was solved continued to wear evenly afterward
Old 06-11-2009, 06:34 AM   #6 (permalink)
Old smart's Avatar
Drive: fortwo premium coupé
Originally Posted by gusfraga View Post
... Any ideas?
Is this issue cover by the warranty? ...
Yes. The front suspension is made up of a long lower wishbone ("A" arm), and a much shorter link between the McPherson strut and the wheel carrier. When the front suspension loads up (a bump or braking or cornering) the wheels will swing up in an arc, resulting in significant temporary negative camber. The inner edge of the tire will then be bearing more weight and wear than the outer edge. If the suspension was the equal length upper and lower wishbone type, the wheel would travel in a straight vertical line with no change in camber.
Dunno if would be a warranty issue, especially if it is an inherent design characteristic.
Old 06-11-2009, 06:45 AM   #7 (permalink)
gusfraga's Avatar
...Dunno if would be a warranty issue, especially if it is an inherent design characteristic.
If is a design issue we have to be prepare to buy front tires every 20.000 miles ....
or turn inside out on the rims to extend the tire life both very bad and expensive options
Old 06-11-2009, 06:49 AM   #8 (permalink)
Old smart's Avatar
Perhaps smart should shoulder the cost and responsibility (TPMS damage).
Old 06-11-2009, 06:52 AM   #9 (permalink)
sato7's Avatar
Drive: 451, rav4, mazda6
most econo cars today are like that! just pay 10 bucks per wheel to dismount and remount them on the other way... its part of maintenance.
Old 06-11-2009, 06:56 AM   #10 (permalink)
gusfraga's Avatar
Having a wider tire can help solve or mitigate the problem?
Front end toe in with bigger tires JimDantin Smart Car Wheels & Tires 2 05-04-2009 11:55 PM
New psi front tires rubyg Smart Car Wheels & Tires 9 04-14-2009 03:18 AM
For Sale: 4 Front Wheels and Tires magilly00 Smart Car Parts Marketplace 8 03-25-2009 08:33 PM
where to buy front tires virenr New Members Area 1 12-24-2008 07:26 PM
Front Wheels and Tires smartah Smart Car Parts Marketplace 5 09-07-2008 07:28 PM
