Using nitrogen vs air in tires - Page 7 - Smart Car of America Forums : Smart Car Forum
Old 11-28-2008, 10:06 PM   #61 (permalink)
Originally Posted by belkin666 View Post
several of the tire seals, like Ultraseal and Ride-on, will provide many of the same benefits plus some added flat tire protection. Yes?
NO!!!!!!!!!!
Tire selants will damage your Tire Prssure Monitor valves which will cost you $50-$100 EACH o replace.
NEVER NEVER use selant in your tires unless you ar willing totrade odd the cost of your valves.
Tireman9 is offline   Reply With Quote
Old 11-29-2008, 09:27 PM   #62 (permalink)
JOIN SCOA.YOU'LL BE GLAD
...you guys know I'm going to take a whack at this dead horse..
..yes..N2 is better...N2 molecules are larger than those found in your 80/20 ...
...check this one out...the real "measured answer".....
http://www.getnitrogen.org/pdf/graham.pdft
if you don't like lengthy reading go towards the bottom of the article.....
jetfuel
Old 11-29-2008, 09:47 PM   #63 (permalink)
Short article..... Not Found ..... Let's just fill the tires with Jet A, and be done with it....... slightly more weight, but a bigger boom.
Old 11-29-2008, 09:56 PM   #64 (permalink)
...sorry... one "t" too many....
and yes ...one of the benefits of N2 is reduced fire hazards...
jetfuel
Old 11-30-2008, 04:40 AM   #65 (permalink)
The only significant advantage to nitrogen is that it will be delivered dry. Many air stations, especially the coin-opderated ones at convenience stores, are not used on a regular basis and condensation builds up in the accumulators. You can get a significant shot of water pumped into your tires. If you really need to use such a pump it is best to sacrifice some change and discharge to the atmosphere first to clear the hose of water. Myself, I take my portable tank to the tire store and have it filled; their compresssors are constantly working and their air is dry.
Directional Tires? SloPok smart Wheels & Tires 5 03-26-2008 09:49 AM
Your POV: Best tires for 451 Smarts SmartAzz smart Wheels & Tires 12 03-22-2008 06:40 PM
Snow Tires canon1753 smart Wheels & Tires 3 02-19-2008 06:54 PM
Snow tires, spare tires, and bears, oh my Djinn smart Wheels & Tires 1 02-02-2008 08:48 AM
Sat in one and kicked the tires North Bay 101 smart News & Rumors 3 06-23-2007 10:32 PM
