Wellsmart Adapter Status/Check out these rims... - Page 2 - Smart Car of America Forums : Smart Car Forum
Old 05-08-2008, 03:44 PM   #11 (permalink)
iconpyro's Avatar
Oh evilution... the only problem I ran into here is translation. Their site doesnt translate over to everything correctly so I have busily cut and paste the German and put it into a language convertor to understand everything. I am going to try to call these guys...but I have a big feeling this might not be that easy to communicate with them.
There prices are decent 150-160 Euro per set, and I will need 2 so roughly about 300Euro along with shipping and conversion to get this to about $450. Don't know if thats about the same as any other. I think the Wellsmart ones were 400 (200 pounds). so this might be equal with shipping.
Well wish me luck... I can only speak a littler German... lol
iconpyro is offline   Reply With Quote
Old 05-08-2008, 03:54 PM   #12 (permalink)
Google "wheel adaptors". There are American companies that make them. They don't make them specifically for Smarts, but if its a half-way decent shop, they should be able to make them to your specs.
Smartbillet is offline   Reply With Quote
Old 05-08-2008, 05:00 PM   #13 (permalink)
I don't know if anyone thought of this yet, but everyone seems to concentrate on 5 lug wheels with adapters. Why not go to a 6 lug wheel. There are wheels available with a 6 x 114.3 bolt pattern. A machine shop could adjust each hole by 1mm +/- to get to a 3 x 112.5 bolt pattern. Offsets would have to be similar, but the bolt pattern issue would be easily fixed. The extra 3 holes on the wheel could be left as is or a dummy lug nut could be attached someway. Lots of 17" rims available.
majerlenbean is offline   Reply With Quote
Old 05-08-2008, 05:14 PM   #14 (permalink)
The problem with that is:
Most 6 lug are truck wheels and not a design that would look good on a Smart.
Finding a wheel with the correct offset might be impossible
Good idea, none the less
Old 05-09-2008, 05:29 AM   #15 (permalink)
Supporting Tuner
Evilution's Avatar
the only problem I ran into here is translation.... I can only speak a littler German...
When I emailed them they replied in perfectly understandable English.
The site also translates what you need to English anyway.
Click catalogues
click adaption wheel spacers
click 3 holed adapters
You will then be shown all of the 3 to 5 adapters.
They are listed in center bore size, I believe you will want the second table which shows the Mercedes 66.5mm bore.
The wording under reference says:
For installation of the rim, a long wheel bolt is necessary.
(original wheel bolt length length plus adapter thickness).
Four of the original bolts can be used.
For original bolts means you can use the 3 standard wheel bolts, buy a set of security bolts to make it 4 and the final long bolt which passes all the way into the hub.
Old 05-09-2008, 06:47 AM   #16 (permalink)
iconpyro's Avatar
Thanks Evilution...
Which button on there is the email button? I was looking for contact information.
Old 05-09-2008, 06:53 AM   #17 (permalink)
Admin/Mod.
Click on the poster's name...
Old 05-10-2008, 04:32 PM   #18 (permalink)
Here is a wheel that would look good on a smart with 6 x 114.3 bolt pattern. It may be a truck wheel but it looks good.
http://www.enkei.com/truck%20specs/RTS.html
Old 05-10-2008, 04:59 PM   #19 (permalink)
Not bad. If you do this, while at the machine shop getting the bolt pattern "adjusted", you'll also need to get them to make you some hubcentric rings for all 4 wheels.
Old 05-15-2008, 12:01 AM   #20 (permalink)
lowndex's Avatar
Don't see anything for the 451
Originally Posted by Evilution View Post
http://www.spurverbreiterung.de/index.php?c=true&lan=uk
They have been doing adapters for years.
Please advise.
LinkBack to this Thread: http://www.smartcarofamerica.com/forums/f64/wellsmart-adapter-status-check-out-these-rims-6342/
smart car rims | Hottags This thread Refback 07-05-2008 09:23 PM
My First Pics (New Rims) lilsmart smart Gallery 10 02-12-2008 05:06 PM
Where to get double din radio adapter? jpkherd smart General Discussion 5 01-30-2008 09:24 PM
What is SMART's offical DOT status? jediknight36 smart General Discussion 0 01-27-2008 09:05 AM
Anybody called the 800# for status?? MikeJCW smart General Discussion 7 01-14-2008 10:24 AM
