wider tires on stock rims - Smart Car of America Forums : Smart Car Forum
Old 03-16-2009, 06:05 PM   #1 (permalink)
john grieco's Avatar
i did a search and found nothing,my apoligies if there is a post.-----
does anyone know what is the widest tires i could put in the back
of my smart on the stock rims---i just want a wider stance,without
breaking the bank,and somthing that will work,anyone with experience
with this,thank you.
john grieco is offline   Reply With Quote
Old 03-16-2009, 06:31 PM   #2 (permalink)
Padawan's Avatar
I wouldn't really go any wider than the stock tire sizes if you're sticking with the stock rims. If all you're after is a wider "stance", you can achieve this with some extended wheel studs and spacers. However, putting a wider tire on the relatively narrow wheel will result in less responsive handling and a "squishier" feel.
Old 03-16-2009, 06:51 PM   #3 (permalink)
For sale pm for details
Turbo42's Avatar
Old 03-16-2009, 06:52 PM   #4 (permalink)
SmartDigger's Avatar
What about a 185/55 15 on the stock front rim?
Old 03-16-2009, 06:59 PM   #5 (permalink)
Turbo42's Avatar
now thats pushing it the front rims are very narrow
Old 03-16-2009, 07:45 PM   #6 (permalink)
hows these
what do u g
15'' staggered packages for 2008 Smart Fortwo
Package Price
Genius Darwin GM Gun Metal wheels
15x6.5 ET22 PCD 3x112 $157.00 each
wheels only:
$628.00 buy now
Full package: 4 wheels + 4 tires $871.54 buy now
Mounting, balancing, lug nuts, valve stems, centering rings (if applicable) are included
General
Exclaim UHP Ultra High Performance tires
Front: 195/50R15 82V (577x195mm) $56.43 each
Rear: 205/50R15 86V (587x205mm) $65.34 each
tires only: $243.54 buy now
DIRECT FIT package. Tires are 10 mm taller than OEM. [ Fitment Guarantee]
The package is shown with closest to OEM fit available tires. See other tire options
Wheels: Gun Metal with Mirror Cut
uys think about this deal? Custom wheels, car rims, truck wheels - RIMS-N-TIRES
Old 03-17-2009, 07:45 AM   #7 (permalink)
I remember at least 1 member here has 185/60 15's mounted
Old 03-17-2009, 09:21 AM   #8 (permalink)
mendo's Avatar
RandyZimmer did it. search his threads.
Old 03-17-2009, 09:23 AM   #9 (permalink)
Randy put 175/55 15's on the stock front rims
Old 03-17-2009, 09:41 AM   #10 (permalink)
RussBarnes's Avatar
I have 185/60-15's all around, but I also installed new rear rims on the front and kept one front for a spare.
Ignoring the 15", these are about as large a tire diameter as will fit the front with this offset wheel. Perhaps a little taller front could be used if the wheel sat in a bit more. Rears could be larger diameter, lots of room - but it is like installing a higher gear ratio and you would feel it during acceleration as it will definitely slow it down.
My end result was that it made the speedometer reading accurate with GPS and radar, but now the odometer reads 3% low. Multiplying the odometer reading by 1.03 and dividing by gallons still gives me an accurate MPG and I am about 43-44 but that is climbing with the use of the MDC cruise control.
I selected Michelin tires for $590 for the set, quiet, good ride and so far very little wear showing.
The Following User Says Thank You to RussBarnes For This Useful Post:
SkippyThorson (02-02-2012)
Looking for a pair of stock rear passion rims/tires kroko smart Wheels & Tires 0 11-01-2008 09:28 AM
Polishing Stock Rims? ex300SRT8 smart Wheels & Tires 14 10-04-2008 01:22 PM
Stock 9 spoke Rims coreyeh Archive/obsolete (?) threads 3 09-10-2008 09:29 AM
WTS- Set of stock smart alloys with stock tires Derek Bell Archive/obsolete (?) threads 3 07-28-2008 03:59 PM
