Originally Posted by suzieleigh
I was thinking of just getting rear snows and keeping the stock tires in the front. Blizzak's come in the 175/55. Do you think that's a good idea or should I just go with all 4 Pirelli tires?
That would work, it will be stable and have traction to avoid getting stuck but will help little with braking, front end grip in the snow will be horrible. (Barely better braking performance and understeer when slipery.)
What ever you do don't use snow tires in the front only, that is dangerous.
If you want to use Blizzak's in the rear and P-190 in the front that should work great too, all four snow tires will help the car stop, turn or avoid obsticles, and help the ABS and stability control be more effective.
