Help!!! (Kia electric issues) - Smart Car of America Forums : Smart Car Forum
Old 03-13-2010, 05:18 PM   #1 (permalink)
Neonspinnazz's Avatar
Sorry I put this in the wrong forum...but I suppose this is serious enough to put in the most active forum on here...
Okay, so no more than 1 hour ago I was changing the headlamps on my Kia. The right one went in fine but the left one was blocked by the battery. So, in my DIY self I decided to remove the battery.
As soon as the screw for the negative terminal came loose, the alarm went nuts. Now I know my car has an alarm system (I don't have a key fob so I just thought that my Kia didn't have the optional alarm).
So, I decided to let my mechanic change the left bulb and tightened the screw. Eventually after hearing the alarm for 5 minutes (after tightening the screw) it goes out.
I get in the car to take it to my mechanic so he can figure out how to get the stupid bulb in and I turn the key from OFF, to ACC (accessories), and as soon as it hits ON/START, the car goes dead.
So now I suppose I didn't screw the negative on good enough so I loosen the screw and get greeted by the alarm, then tighten it back. Once the alarm stopped I got back in and was once again greeted by nothing.
My mind now says "immobiliser" and I check the interwebs to find out I was right. My car does have the optional alarm system but the second-hand dealer never gave me a fob.
If I had a fob, a simple hit at the UNLOCK button would've turned off the immobiliser.
But I have no fob...
So how do I disable the immobiliser?
Or do I have some other problem?
And my mom doesn't like the idea of having to pay to tow or pay to get the alarm disabled.
Old 03-13-2010, 05:38 PM   #2 (permalink)
All's good now!
Look at my last post...
Old 03-13-2010, 06:12 PM   #3 (permalink)
All's good now!
Old 03-13-2010, 06:14 PM   #4 (permalink)
All's good now!
Old 03-13-2010, 08:43 PM   #5 (permalink)
Problem solved! I mended something! (mods, con you move this to off-topic or car lounge please? )
There were two problems
1. Alarm - The previous owner disabled the alarm, when I removed the battery the alarm enabled and started a little pow wow.
2. Battery Connection - The Positive connection was very clean, the negative had some dirt and some other stuff on it.
How they tied together:
When I removed the negative from the battery, the alarm enabled. When I put the negative back on, the car died. This made me think that the immobiliser prevented me from doing something. Somewhere I thought that maybe if the negative terminal was as clean as the positive, it might work. So, I removed the fuse for the horn (#38) so the alarm wouldn't annoy me, cleaned off the terminal, and put it back on.
And lookie here, the car comes back to life!
After it roars back up, I notice that the dash lights are brighter and it doesn't seem like the electrics are taking a load off the battery...I take my mechanic buddy home (has a year in powertrain & brakes) and pull into the garage. As I get out of the car I lock the doors using the door button...crap...there goes that annoying drone of an alarm. I then put my key into the hole, locked all doors (once to right), unlocked all doors (twice to left), and repeated with key #2 and the alarm confirmed and shut off.
And somewhere in between the confusion, I put my new headlamp bulb in!
So, out of 4 hours of frustration I got:
1. A working alarm system (it was disabled before, but now she works!)
2. A new low-beam lamp
3. A more efficient electrical system
4. A little more knowledge about my Kia!
I say I'm a little more than prepared for a smart don'tcha say?
Old 03-13-2010, 10:44 PM   #6 (permalink)
Neon, after that you'll just be bored with the smart's quirks!
Old 03-13-2010, 10:49 PM   #7 (permalink)
As long as the smart's horn isn't louder than my Kia's. I think I went partially deaf today...
All I can hear is "MEEP!!!" "MEEP!!!" "MEEP!!!"
I like D.I.Y. stuff, makes me feel all good on the inside...
Old 03-14-2010, 07:19 AM   #8 (permalink)
happy smarting
GetSmrt28277's Avatar
Sounds like your car angels came through for you. Great job!
GetSmrt28277 is offline   Reply With Quote
Hey NEON..here's a KIA for you !!! chieftmc The Car Lounge 18 03-15-2010 10:46 AM
Forest secretly drives a Kia? Pops900 Off-Topic Cafe 6 03-09-2010 11:56 PM
kia soul - Suze The Car Lounge 19 06-11-2009 12:10 AM
Kia saber777 smart General Discussion 3 04-11-2009 05:56 PM
Why do Kia drivers always want to race? theguywiththelongestname smart General Discussion 7 09-18-2008 03:50 PM
