Lasers to replace spark plugs? - Page 2 - Smart Car of America Forums : Smart Car Forum
Old 04-23-2011, 07:54 AM   #11 (permalink)
Pops900's Avatar
Two things I can think of in my 'non-expertise' of lasers:
- how will the lens remain clean?
- how long will the ending target surface (what solid object the laser runs into) last?
If the same spot gets hit over and over, seems like it would weaken that part of the cylinder wall or piston top.
As far as burning leaner fuel producing less NOx, well, yes it's true, but I believe you will also have less power produced? So you need more fuel to produce the same horsepower output hence the same NOx totals?
It's an interesting concept and would be good to hear their final results. I would imagine that I will not see them in my lifetime since the current spark plugs are pretty cheap and not replaced very often. My Jeep has 80K miles and I have only changed the plugs once. By the time the lasers are of commercial distribution, we will be driving electric cars?
Let's be careful out there,
Pops and Carlito
Pops900 is offline   Reply With Quote
Old 04-23-2011, 08:58 AM   #12 (permalink)
cowancom's Avatar
EcoMotors
Check out Ecomotors. Laser spark induction. 500ft lbs of tourque from a 1.5 liter displacment. Signed a contract with navistar. You can run one in front-one in rear or place them in series. Indy racing is in development.
EcoMotors
EcoMotors, With Navistar as a Customer, Pushes Forward With New Engine | Xconomy
cowancom is offline   Reply With Quote
Old 04-23-2011, 01:20 PM   #13 (permalink)
T-Minus 20 days Colorado
NCC1701's Avatar
As per the article, the laser(s) can be focused to specific points within the combustion chamber. So the bulk of their energy would be focused on igniting the air/fuel mixture, not on the cylinder wall.
The scheme also claims to produce a more efficient and complete combustion, therefore producing fewer NOx compounds. More efficient combustion also means a leaner mix can produce equal HP.
Old 04-23-2011, 05:33 PM   #14 (permalink)
gbryers's Avatar
That will certainly change the nature of a tune-up - instead of cleaning and re-gapping the plug, you will need to re-focus the lasers. A job, by the sound of it, for a TV technician more than mechanic, but it will certainly be interesting to watch this develop!
Old 04-24-2011, 04:09 PM   #15 (permalink)
Whoa, wait a minute here... The article says running leaner gives lower NOx emissions. It actually gives higher NOx emissions. It's the more complete combustion that laser ignition would have potential for that would lower NOx (and CO, and HC) drastically.
deepblueQ is offline   Reply With Quote
Old 04-24-2011, 04:20 PM   #16 (permalink)
NCC1701's Avatar
But, don't you mean a leaner mix produces more NOx with conventional plugs, because they aren't designed for it?
Old 04-24-2011, 05:02 PM   #17 (permalink)
Leaner mix means more O2 left over to combine with atmospheric nitrogen (most of what your car actually breathes, remember) therefore more NOx.
Old 05-05-2011, 11:17 AM   #18 (permalink)
09 Cabrio Caspian Blue
RCRsmart's Avatar
Originally Posted by Kermit View Post
I want a shark with a laser beam attached to its friggin head.
I was hoping someone would post an Austin Powers reference
RCRsmart is offline   Reply With Quote
Pulstar spark plugs chieftmc smart Operation and Maintenance 18 12-12-2010 10:03 PM
Spark Plugs? GeekGirl smart General Discussion 18 08-29-2010 07:46 PM
Spark Plugs At 30k ? a2jack smart Operation and Maintenance 17 10-11-2009 04:08 PM
451 spark plugs jwight smart Operation and Maintenance 20 02-07-2008 04:47 PM
