» Site Navigation |
Helpful Links
smart USA Newsletters
Other Links
» Recent Threads |
08-02-2008, 02:32 PM
#1 (permalink)
Tire failure heads up
08-02-2008, 03:09 PM
#3 (permalink)
Drive: 2008 Smart, Ford Escape
Ditto for me, I shreadded the rear of my Toyota Previa with no noticible driving feel. Perhaps a testiment to the stability of these cars. Oddly, on that section of I-95 I have stopped to help many change tires, etc. Now it was my turn! I was pleased that someone saw me, and stopped. To ask me directions! Oh, well, always happy to help!
08-02-2008, 06:21 PM
#4 (permalink)
Glad to see you made it home safe jwight. How old was the that failed?
Thanks karl
BYW the SCOA sticker looks great on the car
Thanks again
08-02-2008, 06:49 PM
#5 (permalink)
stock Contis
Most people don't know but tires don't just 'blow out'. Blow outs are usually the results of running the tires too low on air where the tires get too hot and the sidewall or tread gives out. In your case Jwight, it was a case of a tire at the end of its life. It looks like a cheap brand as well.
The stock Contis on the Smart is an OK tire. Not a great tire but not an El Cheapo at Sam's either. So just make sure you pay attention to the yellow light for a flat and deal with it before it gets too low or you will experience the dreaded 'blowout'.
08-02-2008, 08:44 PM
#7 (permalink)
And rotate those tires. On another car, I've had to replace 4 sets of tires that were only a year old because of an alignment problem that kept coming back (country roads). Instead of getting the alignment done, I waited... check the tires at the shop and sure enough, the inside has worn down 3x as fast as the outside. $400 for a matching set of 4 tires is a lot more than preventative maintenance and checkups. Rotation won't fix the alignment, but you'll want to even out the wear pattern before the tire gets too worn.
08-02-2008, 11:07 PM
#8 (permalink)
Mad Scientist
cannot rotate from front to rear, cannot rotate from left to right, just gotta pay attention and replace when required.
keep in mind a lot of flats are due to pressure, low pressure mostly, check your tire pressure often, saves the tires and saves fuel!!
08-03-2008, 05:42 AM
#9 (permalink)
smart happens here!
Glad you caught it before it blew at high speed.....and really glad it wasn't a smartie tire - which was my first thought since this is a smart car tire forum. (maybe moving it to the car lounge may cause less people panic when they see this post!)
08-03-2008, 06:43 AM
#10 (permalink)
Drive: 2005 Mazdaspeed Miata
Originally Posted by Quagmire
From the looks of the last picture, that tire was already worn down to the wear bar in the tread. Glad to hear you remained safe.
Take care of your tires people... Your life and others depend on it.
Before you blame jwight for improper maintenance, check out the pictures better. I don't believe that the tires were at the wear bar. I have had a tread separation before and the area where the tire has separated is going to look real worn down. Spin the tire 180 and the tread will be perfect. If you look at the left side of the 1st picture, there is ample tread showing where the belts are not loose.
On another note, If the tires are over 6 years old, it might be wise to start looking into replacement. Rubber gets brittle and can go at any time after that, regardless of mileage. This would go for radiator hoses as well.
By the way jwight, is that a Goodyear tire? It kind of looks like a common Goodyear sidewall pattern.
| Thread Tools |
| Display Modes |
Linear Mode
